k-omega SST for wall-resolved TBL, problem with log layer.
Like Tree9Likes
Old   February 3, 2014, 03:23
Bernhard
Bernhard is on a distinguished road
Originally Posted by aerogt3 View Post
I am a bit lost here with what looks like two conflicting suggestions. If I have a y+1 mesh, and I want to fully resolve the BL (no wall fcns), should I set k = 1e-XX and nut = 1e-XX, or k = kwRWallFunction, with nut set to nutUSpaldingWallFunction?
If you have a proper y+<1 mesh, you should not have problems setting nut=0 and k to zeroGradient. Physically, k goes to zero at the wall with y to some power, so dk/dn=0 or k=0 are equally valid (as long as your mesh is OK, one follows from the other or vice versa). You can check this a posteriori.
For omega I don't know, but I cannot imagine that you want to apply wall functions there. You should look up the limiting behavior of omega(y) for y to 0. I don't know whether OpenFOAM is shipped with these kind of boundary conditions.
Bernhard is offline   Reply With Quote
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 01:35
[snappyHexMesh] snappy hangs while layer generation bastil OpenFOAM Meshing & Mesh Conversion 3 October 29, 2010 08:19
problem with boundary layer Bharath Main CFD Forum 1 July 11, 2008 10:06
GAMBIT problem with 3D Boundary Layer when meshing Anthony Haroutunian FLUENT 2 March 26, 2008 03:02
problem in convergence with the prism layer genera rakesh CFX 3 September 18, 2006 11:13
