March 12, 2012, 17:57 |
Restart using different boundary conditions
Attesz
Rep Power: 17 |
Hi all,
what is the best way if I want to restart the simulation but I have new BC types and values? mapping or can I change it in the results file? I have 15M cells so opening a result file is not so straightforward :P Best, |
March 13, 2012, 02:58 |
Niels Nielsen
Rep Power: 27 |
Hi.
As you said either you map or you use some clever sed/regex that does search and replace in the result files. Sed would probably be faster since mapping 15M cells can take quite some time. Best
Linnemann PS. I do not do personal support, so please post in the forums. |
March 13, 2012, 05:29 |
Martin
Rep Power: 22 |
the "changeDictionary" utility with an appropriate changeDictionaryDict might be a good choice, too. Martin |
March 13, 2012, 05:35 |
Attesz
Rep Power: 17 |
Thank you all! I'll have a look at the changeDictionary utility!
Best regards, Attila |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 14:06 |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 13:58 |
symmetry boundary conditions in cfx | lost.identity | CFX | 41 | May 22, 2013 08:21 |
restart after changing boundary conditions | aperrone | STAR-CD | 5 | April 25, 2011 21:53 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
