Jet cross flow in a cylindrical mesh
Old   March 12, 2012, 11:16
Default Jet cross flow in a cylindrical mesh
Charlie
shackman287 is on a distinguished road
I have a finely meshed cylinder (good checkMesh). There is a jet flow of water entering the bottom of the cylinder and a cross flow of air from the sides of the cylinder. I had to split the two cylinder walls in two (for an inlet and outlet). The jet alone works, but when introducing the cross flow it crashes and U blows up in the solution but the residuals all look fine (1e-05 initial residual). But the adjustable time step causes the time step to go amazingly low. I can't find the right BC's for the inlet and outlet of the crossflow patches and have tried near everything. I think the problem is that the two patches are wrapped around the cylinder and meet on both ends, this must cause a problem when forcing certain BC's.
Any suggestions as to which BC's i should use on the two side patches (outer circumference split evenly in two) to have a 40 m/s cross flow.
thank you
shackman287 is offline   Reply With Quote
Old   March 13, 2012, 03:03
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
Can you please post a sketch or the CAD-file or the case?
Also some info on the actual BC the output of the last iterations schemes and solver would help us to help you.
This will make it a lot easier to help as the description you give doesn't give a clear picture unless you work with cross-flow problems on a daily basis.
Best
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Nu values come up too high for cylindrical pipe turbulent flow Onur10 FLUENT 7 February 21, 2016 13:59
Trajectory of particles in a jet in cross flow forgottenman FLUENT 0 November 29, 2011 03:43
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
LES of jet in cross flow dirk FLUENT 0 April 25, 2005 09:39
Mesh for 3 dim Geometry Phil FLUENT 9 July 12, 2000 05:39
