Conflict between y+, cell size and particle deposition |
March 6, 2012, 19:03 |
Rep Power: 18 |
Hi there,
I'm hoping you can put me straight here: I'm investigating particle deposition onto indoor surfaces. Therefore Reynolds numbers are generally less than 10,000. So I'm using a wall function which requires y+ in the first cell to be about 30. Mine are, however, often about 1. Therefore this gives me incorrect results. However I need sufficient grid resolution for accurate particle deposition. What are your recommendations? Regards, |
March 6, 2012, 21:51 |
#2 | |
mauricio
Rep Power: 18 |
i haven't rly done any turbulent simulations in openfoam w/o wall functions. Some say that you may need y+ as small as 0.1 to resolve the whole thing properly but i guess that depends on the turbulence modeling/intensity edit: guess that you'll have to use low-re models to resolve the BL... try LaunderSharmaKE ras incomp/comp model or the new transition incompressible one kklOmega set zero gradient on walls and respective values at inlet and outlet!? can any1 with xp in this topic back me up? or maybe correct me? sry kingj, but i cant help you any better hope it helps somehow
Best Regards /calim "Elune will grant us the strength" Last edited by calim_cfd; March 6, 2012 at 22:38. |
March 7, 2012, 07:18 |
#3 | |
Rep Power: 18 |
Cheers, |
March 7, 2012, 08:11 |
#4 | |
mauricio
Rep Power: 18 |
try setting usual turbulent setting on patches and zeroGrad on walls and c what you get! if i have more time i'll try checking some references cuz i'm interested in that 2!!!!! sry to be of no help
Best Regards /calim "Elune will grant us the strength" |
March 7, 2012, 09:57 |
mauricio
Rep Power: 18 |
ok i've looked a bit more into the topic and i confess this is one of the most puzzling topics in cfd for me...i'm still reading Pope's book of turbulence for better modeling theory but atm this is what comes to me from my current knowledge
let's rate: 1:we all know the scale issues related to HiRe lowRe numbers and bounded flows 2:you either have turbulence or you don't! 3:if you do, you have to choose between low or high Re turbulence modeling (lets stick with RAS) 4[edited]: removed 5[edited]: wallfunctions... kinda routine settings for hiRe.. BUT, to resolve a bl you need a lowRe Ras model: have a refined mesh with low y+=1, use calculated type for nut/mut (few say zeroGrad wont change much), zeroGrad for k/epis or very small values like 1e-10 on walls ==>>zeroGrad for k/epis or very small values like 1e-10 on walls: i guess that in the limit they should yield similar results? no? == any comments/corrections to this are most welcome!!! == 6[edited]: removed check this pdf, http://www.google.com.br/url?sa=t&rc...Py7KIzWAuhcT1w maybe it will point sth you may have missed guess that's all i can try to help you with! EDIT: sry about the editing but i corrected some assertions made previously
Best Regards /calim "Elune will grant us the strength" Last edited by calim_cfd; March 8, 2012 at 15:02. |
Pls help UDF about particle size (Rosin-Rammler) | ch3coohminh | Fluent UDF and Scheme Programming | 8 | January 22, 2016 10:47 |
Particle size show on DEM solver | chandi | STAR-CCM+ | 9 | May 15, 2013 07:41 |
SPH particle vs. real fragment size | Katarina | FLUENT | 0 | April 8, 2009 10:48 |
Particle Size Distribution with R-R fails? | HP | FLUENT | 6 | May 19, 2005 07:35 |
Particle size distribution-concentration contours | Umesh Shah | FLUENT | 3 | July 22, 2003 15:46 |
