InterDyMFoam with rotating reference frame
Old   March 1, 2012, 10:28
Question InterDyMFoam with rotating reference frame
Francesco
frank79 is on a distinguished road
Dear all,
I'm using InterDyMFoam to simulate a multiphase problem in which I need to refine dinamically the mesh according to the interface position as follows:
|  \\    /   O peration     | Version:  1.6                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      dynamicMeshDict;
//dynamicFvMesh   staticFvMesh;
dynamicFvMesh   dynamicRefineFvMesh;
dynamicRefineFvMeshCoeffs
    // How often to refine
    refineInterval  1;
   // Field to be refinement on
        field           alpha1;
    // Refine field inbetween lower..upper
    lowerRefineLevel 0.001;
    upperRefineLevel 0.999;
   // If value < unrefineLevel unrefine
    unrefineLevel   10;
   // Have slower than 2:1 refinement
    nBufferLayers   1;
        // Refine cells only up to maxRefinement levels
    maxRefinement   2;
        // Stop refinement if maxCells reached
    maxCells        2250000;
       // Flux field and corresponding velocity field. Fluxes on changed
    // faces get recalculated by interpolating the velocity.
        correctFluxes
                phi
            U
    // Write the refinement level as a volScalarField
       dumpLevel       true;
Now I want to place my computational domain in a non inertial reference frame (i.e. rotation around z axis) keeping the dynamic mesh refinement due to the interface position.
Do you know how I can manage this issue?
Thanks in advance
Francesco
frank79 is offline   Reply With Quote
Old   March 2, 2012, 12:25
Default new code
Francesco
I decided to hack the code of InterDyMFoam to add the Coriolis and the centrifugal term. At the moment I'm adding the SRFModel to the original InterDyMFoam. I'll let you know if it will work
bye
Old   July 2, 2012, 06:41
Albrecht vBoetticher
vonboett is on a distinguished road
Hi Francesco,
I model a rotating drum partially filled with liquid, including internal faces using interDyMFoam, I use the solid-body motion function rotatingMotion and apply it to a cellZone containing the whole grid. Since the simulation always crushes after mesh.update() and I am stuck, I thought maybe you could post your fvSolution and fvSchemes dict because you seeem to be more successful?
Thanks,
Albrecht
vonboett is offline   Reply With Quote
dynamic mesh, interface position, multiphase flow, reference frame
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 05:28
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
