waves2Foam waveFlume reflections
Old   February 29, 2012, 18:15
Default waves2Foam waveFlume reflections
Betsy Seiffert
Betsy is on a distinguished road
Hello - I have just installed the waves2Foam library on OFv2.1.1 and have run the tutorial waveFlume. The wave appears linear at the beginning but soon there is a reflected wave that distorts the incoming wave. The video is here: http://youtu.be/VwNF65Fkdbo
Can anyone offer an explanation or a fix??
Thank you,
Betsy
Betsy is offline   Reply With Quote
Old   February 29, 2012, 21:55
Betsy Seiffert
Ok, I have extended the domain length and it appears the left running wave interfering with the right running wave is not a reflection. Here is a video: http://youtu.be/yfZ1eXDDa4s
Again, I'm not sure what is causing this. Any help is appreciated.
Thanks,
Betsy
Old   February 29, 2012, 23:14
Dave
daveatstyacht is on a distinguished road
Betsy,
Your wave's amplitude appear to be quite large relative to the wave length which may mean that linear wave theory might not be the best choice. Try running smaller wave amplitudes and see if the behavior persist. I have not had any issues with strange behavior in that tutorial for reasonable amplitudes.
Dave
daveatstyacht is offline   Reply With Quote
Old   March 1, 2012, 03:40
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Betsy
What you see is exactly caused by the large amplitude linear wave in shallow waters. The explanation is as follows:
The first example is the spatial change of a sinusoidal wave of finite wave height, which is generated at the inlet over a horizontal bed. The prescribed sinusoidal motion does not satisfy the complete non-linear wave problem, hence bound higher order harmonics are generated adjacent to the boundary. In order to fulfil the first order theory at the boundary, however, spurious free higher harmonics are likewise created, which have amplitudes equal to their bound counterparts, but with opposite phase, such that they cancel one another at the inlet. Interaction between these harmonics leads to an energy transfer, which can be identified as beat lengths, see [24] for further details.
where the quote is taken from our article:
@article { jacobsenFuhrmanFredsoe2011,
Author = {Jacobsen, N G and Fuhrman, D R and Freds\o{}e, J},
title = {{ A Wave Generation Toolbox for the Open-Source CFD Library: OpenFoam\textregistered{} } },
Journal = {{ Int. J. Numerl. Meth. Fluids} },
Year = {In print},
Volume = {},
Pages = {},
DOI = {{10.1002/fld.2726} },
If you choose stokesSecond instead, you should experience that the rate of energy exchange decreases, since the spurious waves generated will be of third order.
Kind regards,
Niels
ngj is offline   Reply With Quote
Old   March 1, 2012, 20:17
Betsy Seiffert
Yes, this makes sense. Thank you both for your replies.
Betsy
Old   August 24, 2013, 05:48
Default An error in waveFlume test of waves2Foam
rz
rezacfd1361 is on a distinguished road
Hy guys,
I tried to run the tutorial waveFlume from waves2Foam. I run blockMesh and the mesh generated successfully. Now I want to see the mesh by paraview and after typing: paraFoam I got this error :
WARN file does not exist:
./system/fvSchemes
./system/fvSolution
created temporary 'waveFlume.OpenFOAM'
Application asked to unregister timer 0x63000017 which is not registered in this thread. Fix application.
My OpenFOAM version is 2.1.1. Would you tell me how can I fix this error?
Thanks
rezacfd1361 is offline   Reply With Quote
Old   August 24, 2013, 05:52
Default waves2Foam
rz
Hi guys,
Is there a user guide for using waves2Foam?
Old   August 24, 2013, 06:53
ngj
The only thing around would be the forum and especially this thread:
http://www.cfd-online.com/Forums/ope...ed-topics.html
and the wiki-page
http://openfoamwiki.net/index.php/Contrib/waves2Foam
Kind regards
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
waveflume, wavefoam, waves2foam
How to find the reflections of the pressure wave in pipe lines RKR Main CFD Forum 0 April 6, 2011 09:08
Shock Reflections in Fluent Richard FLUENT 2 September 2, 2004 10:55
