Incomp. LES in pisoFOAM, how to set up Smagorinsky model with van Driest dampin
Like Tree3Likes
Old   August 10, 2016, 07:31
Post
  #21
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
Originally Posted by Esther Jin View Post
Hello, I am doing LES turbulence simulation using OpenFOAM3.0.1, and have some questions about the turbulenceProperties in the constant folder of pitzDaily in tutorials, I don't understand what LESdelta means, is it related to filter width?
simulationType  LES;
LES
    LESModel        dynamicKEqn;
    turbulence      on;
    printCoeffs     on;
    delta           cubeRootVol;
    dynamicKEqnCoeffs
        filter simple;
    cubeRootVolCoeffs
        deltaCoeff      1;
    PrandtlCoeffs
        delta           cubeRootVol;
        cubeRootVolCoeffs
            deltaCoeff      1;
        smoothCoeffs
            delta           cubeRootVol;
            cubeRootVolCoeffs
                deltaCoeff      1;
            maxDeltaRatio   1.1;
        Cdelta          0.158;
    vanDriestCoeffs
        delta           cubeRootVol;
        cubeRootVolCoeffs
            deltaCoeff      1;
        smoothCoeffs
            delta           cubeRootVol;
            cubeRootVolCoeffs
                deltaCoeff      1;
            maxDeltaRatio   1.1;
        Aplus           26;
        Cdelta          0.158;
    smoothCoeffs
        delta           cubeRootVol;
        cubeRootVolCoeffs
            deltaCoeff      1;
        maxDeltaRatio   1.1;
If I choose VanDriest as Delta, in log file it shows the LES delta type selected twice,
PHP Code:
PIMPLEOperating solver in PISO modeReading field pReading field UReading/calculating face flux field phiSelecting incompressible transport model NewtonianSelecting turbulence model type LESSelecting LES turbulence model SmagorinskySelecting LES delta type vanDriestSelecting LES delta type cubeRootVolSmagorinskyCoeffs{    Ck              0.094;    Ce              1.048;}
I also want to use Van Driest damping function, but I am so confused with these LES deltas and coefficients. Could anyone please explain me about these parameters if you have experience with LES turbulent flow simulation?
Thank you in advance!
Best regards,
Esther
Hi Esther.
This reply isn't a reply because i'm not an expert in LES, though i've read a few things about. And from my readings, i believe you should read get more familiar with the concept of filtering and the available turbulence models in OF. The parameters may change from model to model.
It is just a suggestion because you may bump into errors and not be able to debug them because it is a "dimensioning issue", even thou OF is now more user friendly :P
You may try these books along with a few dozen papers
https://www.amazon.com/Turbulent-Flo...urbulence+pope
https://mitpress.mit.edu/books/first-course-turbulence
Sorry i could not help you
Best Regards
/calim
"Elune will grant us the strength"
calim_cfd is offline   Reply With Quote
Old   August 10, 2016, 13:03
Mahdi Hosseinali
anishtain4 is on a distinguished road
First it's odd that you have "delta cubeRootVol;" in your turbulenceProperties and it is using vanDriest! It usually should be "delta vanDries;".
You can have a good read about the delta and wall functions of LES simulation in OpenFOAM in this topic:
http://www.cfd-online.com/Forums/ope...nel-flows.html
anishtain4 is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
LES Compressible Smagorinsky Model iyer_arvind OpenFOAM Running, Solving & CFD 26 September 9, 2014 08:22
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 06:24
Smagorinsky closure model for LES Jimmy FLUENT 0 December 18, 2002 05:33
2-equation model of LES and source code M.R.Hadian Main CFD Forum 0 February 3, 2002 06:00
