February 23, 2012, 20:47 |
aeration tank with particle suspension
Rep Power: 14 |
Hi all,
I am beginning a final year thesis in my engineering degree, in which I am attempting to model the flow inside an aeration tank with particles suspended in water. I am quite new to OpenFOAM (and CFD in general) so am doing a fair bit of research into how exactly I will setup the problem, what solver I will use etc. I understand that this is a fairly complex task. My thinking is that I will use bubbleFoam to simulate the flow. However I was wondering if it is possible to incorporate a one-way coupled lagrangian particle tracking simulation and insert the suspension particles into the flow? Does anyone have any ideas about how to go about a problem like this? The suspension particles are actually quite large, pieces of seaweed roughly 1-2cm long, from what I understand lagrangian particle tracking in OpenFOAM will use spherical particles. Are there methods of modelling different shaped particles in OpenFOAM? I understand that I havent really defined the problem yet I am trying to get a feel for the options available with OpenFOAM. Any help would be greatly appreciated!! Cheers Matt |
bubblefoam, coupled, multiphase flow, particle tracking |
dispersion model with lagragian particle tracking model for incompressible flows | eelcovv | OpenFOAM Running, Solving & CFD | 54 | April 10, 2018 10:36 |
DPM particle tracking in stirred tank | parisa- | FLUENT | 1 | August 7, 2012 13:03 |
Particle tracking in Mixing tank | zhang.limin | FLUENT | 0 | November 12, 2010 21:23 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 02:29 |
particle tracking collection tank | Neser | CFX | 1 | June 1, 2006 11:06 |
