February 16, 2012, 11:00 |
Time step continuity errors
Alejandro Alonso Fuster
Dear fellows: I'm currently working in the simulation of a turbulence fluid contained in a mixing tank. I obtained the mesh in Gambit and successfully imported by using fluent3DMeshToFoam command, once checked all the aspects are reported as OK. When I run the simulation employing the MRFSimpleFoam solver, the bounding epsilon starts to increase and in around 10 iterations it's in the order of 1e-54 to 1e+55 and of course exceeds the double precision of the methods. I attach an image with the results showed in FOAM console. Could somebody please illustrate me about that issue, I obtained convergent solutions in Fluent for the same problem so I'm completely sure it's perfectly possible in OpenFOAM too. With best regards
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
Problem with FloatingObject | Leech | OpenFOAM Running, Solving & CFD | 10 | March 29, 2012 15:24 |
time step continuity errors?? | CFT | OpenFOAM Running, Solving & CFD | 2 | June 26, 2009 09:29 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
