flow controled by outlet temperature
Old   January 30, 2012, 10:07
Default flow controled by outlet temperature
soonic's Avatar
Peter
soonic is on a distinguished road
Send a message via ICQ to soonic Send a message via AIM to soonic Send a message via Skype™ to soonic
Let's have a water boiler - closed tank full of water. The hot water is outleted from the top, cold water is inleted in the bottom.
Inlet water temperature is to be fixed. Outlet temperature changes accordingly to heat ballance and transfer in the system.
To keep the ammount of consumed heat, I need to change the inlet=-outlet mass flux (or velocity) on deltaT of the system. With other words: to control mass flux by outlet water temperature.
How to realize this ? Give me a direction, please.
Is it a case for groovyBC ?
It should be the start of some design test case. The idea is to solve it in transient. Is the buoyantBoussinesqPimpleFoam suitable solver for that simple case?
Thanks a lot
soonic is offline   Reply With Quote
b.c., control, tank
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 13:30
CFDesign V11 -- Reverse flow at outlet maruthiv Autodesk Simulation CFD 1 June 17, 2011 10:38
Pressure outlet in two-phase flow in horizontal 2D channel AlmostSurelyRob Main CFD Forum 0 November 17, 2010 08:32
Inlet and outlet flow rate Neser CFX 1 March 2, 2004 17:02
Question on checking incell temperature at outlet Guoqing Phoenics 1 June 4, 2003 18:50
