Using pimpleFoam to model pulsatile flow in a micro channel |
January 30, 2012, 01:03 |
I have been trying to use the pimpleFoam solver to solver pulsatile flow moving through a rectangular micro channel with flow in the x direction. The viscosity being used is the kinematic viscosity of 2.3e-006 m^2/s with the dimensions of the channel to maintain a Re of around 5.2. The flow is incompressible and transient (unsteady). The pressure solver appears to max out at 1000 iterations, any suggestions as to what may cause this? Thank you in advance Last edited by isaacp; February 16, 2012 at 18:51. |
channel, micro, pimplefoam, pulsatile flow |
Yacht in Open Channel Flow | andreimour | FLUENT | 1 | October 15, 2010 00:54 |
Ho to model the flow in a Regenerator | alexandrepereira | OpenFOAM Running, Solving & CFD | 2 | August 25, 2010 18:35 |
Flow within a thin channel | al0Vera | FLUENT | 0 | June 15, 2009 11:20 |
Multiphase flow. Dispersed and free surface model | Luis | CFX | 8 | May 29, 2007 19:13 |
compressible channel flow.. | R.D.Prabhu | Main CFD Forum | 0 | July 17, 1998 18:23 |
