August 20, 2015, 16:12 |
#21 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
May 20, 2016, 23:57 |
#22 |
musaddeque hossein
Rep Power: 18 |
Gautami: did you do any postprocessing on the generated data? What do the data files look like?
November 24, 2019, 12:28 |
Need help with changing the floating object to a .stl file cylinder
#23 |
Ahsan
Rep Power: 7 |
I have a question, can someone please help me out?
I want to run the solver multiPhase/interFoam/RAS/floatingObject but by default it runs with a cuboid body, I have a cylindrical body in .stl format and I want to use it as a floating object. How can I do this? I have been able to insert the cylindrical mesh in blockMesh by using snappyHexMesh, but how can I use the cylinder as a floating object? Thanks if someone can help me out, I am doing a univerisity homework |
[foam-extend.org] Error compiling OpenFOAM-1.6-ext | Canesin | OpenFOAM Installation | 137 | January 20, 2016 15:56 |
Floating object tutorial case in OpenFOAM 1.7 | sega | OpenFOAM Running, Solving & CFD | 11 | February 9, 2012 05:29 |
Inserting a floating object on a restart | RileyJ | FLOW-3D | 0 | October 24, 2011 17:05 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 05:55 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
