ggi and "uncovered faces found"
Old   January 25, 2012, 07:02
Default ggi and "uncovered faces found"
Aqua
aqua is on a distinguished road
Hello everyone,
I am trying to perform a simulation about two cars passing by each other. Please find attached picture about the mesh.
so there are two cubes standing for two cars. Iblock and oblock, containing the two cars(cubes), will move towards each other. So, interfaces between iblock and oblock is defined as ggi. I used the tutorial turboPassengeRotating.
I run
" setSet -batch setBatch
regionCellSets
setsToZones -noFlipMap" there is no error.
then i run decomposePar, OF didn't abort, but there is some information like
:"Processor 0: field transfer
Initializing the GGI interpolator between master/shadow patches: interfacei/interfaceo
From function void GGIInterpolation<MasterPatch, SlavePatch>::rescaleWeightingFactors() const
in file /bb/civ/liuyu/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/GGIInterpolationWeights.C at line 544
Uncovered faces found. On master: 120 on slave: 120
Processor 1: field transfer
Processor 2: field transfer
Processor 3: field transfer
End."
Could anyone tell me, Does "uncovered faces found" mean, the mesh or GGI setting is not right? If you look at my geometry, you would find that interfacei and interfaceo don't match each other totally, so there should be "uncovered faces"? or not?
Please help!
Aqua
aqua is offline   Reply With Quote
Old   October 29, 2019, 01:41
Bidesh Sengupta
BSengupta is on a distinguished road
Did you found the reason?
BSengupta is offline   Reply With Quote
