Breaking of constraint conditions
Old   January 13, 2012, 09:28
Unhappy Breaking of constraint conditions
Ivan
lt.quibbler is on a distinguished road
Hi, foamers!
I've faced a very strange problem while trying to calculate the 2DoF movement of a cuboid in a canal with interDyMFoam. Cuboid is half submerged in water and the inflow velocity in longitudinal direction ( X ) is 0.5 m/s. I use the constraint fixedLine in the vertical ( Z ) direction ( not to let the cuboid move downstream the canal ) and fixedAxis around Y-axis ( to let only the trim change ).
For some time the constraint condition is satisfied, but after 2-3 seconds of model time, the object starts shifting downstream the canal ( along the X-axis ), and the shifting velocity is quite large. I see this movement in Paraview, but when I look at the log it reports that the body is moving not in the X-direction but in Z direction ( ! ).
So, there are two questions:
1. Why the constraint condition is not satisfied after some time?
2. Why the log and the actual mesh movement ( in Paraview ) do not coincide.
I use OpenFOAM 2.1.x, but this behavior can be seen in earlier versions too.
I tried to make the same simulation in OF 1.6 ext , but it gave the similar result.
I also tried using different constraint combinations, varying the relaxation factor and tolerance - still no effect.
The only way I've found to reduce this movement is to increase the inertia moments ( ! ) ( But I can not understand, how they are connected. )
Has anybody faced such problems?
lt.quibbler is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 06:58
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 02:54
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 19:29
