boundary conditions on mhdFoam duct flow
Old   January 8, 2012, 14:40
Default boundary conditions on mhdFoam duct flow
fferroni is on a distinguished road
Hello everyone,
I have a question regarding the mhdFoam solver in openFOAM.
In the mhdFoam.c description is says that one cannot set any boundary conditions from \vec{J} or the electric potential. Very well... so:
If one needs to set the boundary conditions that describe a wall as i.e. perfectly conducting or perfectly insulating, then how does one go about it (if at all)?
In an induction based approach (I think this is what mhdFoam is), then a perfectly insulating wall would have the induced magnetic field b = 0, and in a perfectly conducting wall db/dn = 0.
Suggestions?
Thanks,
Francesco
fferroni is offline   Reply With Quote
Old   November 14, 2012, 06:32
Default BC
Lev
levka is on a distinguished road
for conducting walls apply for B: zeroGradient at the walls + initial cond.
for insulating walls apply for B: B (.. .. ..) at the walls + initial cond.
got it?
levka is offline   Reply With Quote
Old   July 1, 2024, 10:41
Omar
itaniOmar is on a distinguished road
got it?
Hello,if u r still active can i ask you further questions regarding the mhdfoam solver?For instance when taking the tutorial if i give a high enough value for B like (0 100 0) the solver doesn't work.Also when i change the properties from 1 to those ocrresponding of a plasma or liquid sodium for my case the solver also doesn't give converging results.It would be greatly appreciated if u can give ur input.
Best regards
itaniOmar is offline   Reply With Quote
Old   October 9, 2024, 13:51
alij
ajnaqvee is on a distinguished road
Best regards
Did you find some solution to the second question because I am facing the same issue when changing the transport properties from 1 to some other?
ajnaqvee is offline   Reply With Quote
boundary condition, duct, mhd, mhdfoam
non reflective boundary conditions for incompresible flow Pascal_doran OpenFOAM Programming & Development 16 August 25, 2015 06:35
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 18:15
Open Channel Flow Boundary Conditions TWaung STAR-CCM+ 2 October 7, 2011 01:37
Boundary conditions low Mach number flow lost.identity Main CFD Forum 0 November 28, 2010 05:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
