January 9, 2012, 12:11 |
#21 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
You can open another bug report with a feature request
January 9, 2012, 18:11 |
#22 |
Alberto Passalacqua
Rep Power: 36 |
You can re-open the bug report I think (scroll down the page).
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
January 10, 2012, 04:38 |
#23 |
Bruno Santos
Rep Power: 128 |
Nope, only the original poster can re-open his/her own bug report. And I've reported before about this and... see for yourself: http://www.openfoam.com/mantisbt/view.php?id=228
January 10, 2012, 09:51 |
#24 | |
Alberto Passalacqua
Rep Power: 36 |
January 25, 2012, 19:57 |
#25 |
Bruno Santos
Rep Power: 128 |
Hi Alberto and Daniel,
I think mantis has an option for this... but I'm not 100% certain about this By the way, to close the loop on this thread, a proper solution has been implemented for the issue that lead to the creation of this thread! Seen here: http://www.openfoam.com/mantisbt/view.php?id=382#c950 - the aforementioned commit is this one: https://github.com/OpenFOAM/OpenFOAM...e6cf8aa2c9bf39 Apparently the solution was a lot simpler than I first deduced... I thought there would be far more logical/cyclic issues with these variables, but I didn't look deep enough into an actual solution Best regards, Bruno
January 25, 2012, 20:19 |
#26 |
Daniel WEI (老魏)
Rep Power: 21 |
It's good to see Henry's revision.
if (timeDict.readIfPresent("deltaT", deltaT_)) // Read and set the deltaT only if timestep adjustment is active // otherwise use the deltaT from the controlDict if (controlDict_.lookupOrDefault<Switch>("adjustTimeStep", false)) { deltaTSave_ = deltaT_; deltaT0_ = deltaT_; if (timeDict.readIfPresent("deltaT", deltaT_)) { deltaTSave_ = deltaT_; deltaT0_ = deltaT_; } }
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
November 1, 2012, 03:19 |
What would be the reason for this
#27 |
Suranga Dharmarathne
Rep Power: 15 |
Hi Bruno, Daniel, Albreto and others,
I created tempPimpleFoam solver adding T field into basic pimpleFoam. And I tested it for pitzDaily tutorial case. But when I run the actual case it gave me the following error massage after running few iterations. deltaT = 1.58835e-65 --> FOAM Warning : From function Time:erator++() in file db/Time/Time.C at line 1010 Increased the timePrecision from 145 to 146 to distinguish between timeNames at time 0.00166302 Time = 0.001663021666070488464861387711835050140507519245 147705078125 I could see that deltaT is keep on reducing and timePrecision value was adjusting in every timestep. Sorry I can not attach the test case since the forum file size is very small. Any idea would be appreciated. Best regards, Suranga. |
October 23, 2019, 18:48 |
similar problem
#28 |
Brett
Rep Power: 14 |
Hey guys,
I'm getting super small time steps: circa 1x10^-8 when I've set my deltaT to 0.001 Anyone know why its doing this? Also does anyone have any best practice tips for getting a fireFoam simulation to run a bit faster? for example can you get by with a course mesh? any parameters in fvSchemes or fvSolution that you would recommend? I'm aware LES solvers take a long time to solve but mine is taking a bit too long I think. This is my fvSolution file: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: dev | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "(rho|rhoFinal)" { solver PCG; preconditioner DIC; tolerance 1e-6; relTol 0; }; p_rgh { solver GAMG; tolerance 1e-6; relTol 0.1; smoother GaussSeidel; }; p_rghFinal { $p_rgh; tolerance 1e-6; relTol 0; }; ph_rgh { $p_rgh; } "(U|Yi|k|h)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-6; relTol 0.1; nSweeps 1; }; "(U|Yi|k|h)Final" { $U; tolerance 1e-6; relTol 0; }; Ii { solver GAMG; tolerance 1e-4; relTol 0; smoother symGaussSeidel; maxIter 1; nPostSweeps 1; } G { solver PCG; preconditioner DIC; tolerance 1e-04; relTol 0; } } PIMPLE { nNonOrthogonalCorrectors 2; pRefPoint (1 0 0.25); pRefValue 84437; momentumPredictor yes; nOuterCorrectors 1; nCorrectors 2; nNonOrthogonalCorrectors 0; hydrostaticInitialization yes; nHydrostaticCorrectors 5; } relaxationFactors { equations { "(U|k).*" 1; "(CH4|O2|H2O|CO2|h).*" 1; } } // ************************************************** *********************** // Followed by fvSchemes: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: dev | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) Gauss LUST grad(U); div(phi,K) Gauss linear; div(phi,k) Gauss limitedLinear 1; div(phi,Yi_h) Gauss multivariateSelection { O2 limitedLinear01 1; C12H24 limitedLinear01 1; N2 limitedLinear01 1; H2O limitedLinear01 1; CO2 limitedLinear01 1; h limitedLinear 1; }; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; div(Ji,Ii_h) Gauss upwind; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } // ************************************************** *********************** // |
August 8, 2020, 02:07 |
#29 |
I have a similar question about time control when using overPimpleDyMFoam in OpenFOAM v2006. It's weird that I lose the data for the last few time steps when I try to write out data every 10 time steps.
I tried different combinations but none of them work. Option 1: Code:
deltaT 0.00001028; // small time step to reduce CFL writeControl adjustableRunTime; writeInterval 0.0001028; // every 10 time steps to save space runTimeModifiable yes; // changing to 'no' doe not work either adjustTimeStep no; timePrecision 10; //time precision is enough Option 2: Code:
deltaT 0.00001028; writeControl timeStep; writeInterval 10; runTimeModifiable no; adjustTimeStep no; timePrecision 10; Code:
deltaT 0.00001028; writeControl runTime; writeInterval 0.0001028; // = 10 time steps runTimeModifiable no; adjustTimeStep no; timePrecision 10; Here is the complete controlDcit for the first one: Code:
application overPimpleDyMFoam; startFrom latestTime; deltaT 0.00001028; startTime 0.0073502; endTime 0.0147004; //0.294008 writeControl adjustableRunTime; writeInterval 0.0001028; //writeControl timeStep; //writeInterval 10; //writeControl runTime; //writeInterval 0.0001028; purgeWrite 0; writeFormat binary; writePrecision 10; writeCompression off; timeFormat general; timePrecision 10; runTimeModifiable yes; adjustTimeStep no; maxCo 2.0; maxDeltaT 0.0001028; Code:
time time difference 0 0.0001028 0.0001028 0.0002056 0.0001028 0.0003084 0.0001028 0.0004112 0.0001028 0.000514 0.0001028 0.0006168 0.0001028 0.0007196 0.0001028 0.0008224 0.0001028 0.0009252 0.0001028 0.001028 0.0001028 0.0011308 0.0001028 0.0012336 0.0001028 0.0013364 0.0001028 0.0014392 0.0001028 0.001542 0.0001028 0.0016448 0.0001028 0.0017476 0.0001028 0.0018504 0.0001028 0.0019532 0.0001028 0.002056 0.0001028 0.0021588 0.0001028 0.0022616 0.0001028 0.0023644 0.0001028 0.0024672 0.0001028 0.00257 0.0001028 0.0026728 0.0001028 0.0027756 0.0001028 0.0028784 0.0001028 0.0029812 0.0001028 0.003084 0.0001028 0.0031868 0.0001028 0.0032896 0.0001028 0.0033924 0.0001028 0.0034952 0.0001028 0.003598 0.0001028 0.0037008 0.0001028 0.0038036 0.0001028 0.0039064 0.0001028 0.0040092 0.0001028 0.004112 0.0001028 0.0042148 0.0001028 0.0043176 0.0001028 0.0044204 0.0001028 0.0045232 0.0001028 0.004626 0.0001028 0.0047288 0.0001028 0.0048316 0.0001028 0.0049344 0.0001028 0.0050372 0.0001028 0.00514 0.0001028 0.0052428 0.0001028 0.0053456 0.0001028 0.0054484 0.0001028 0.0055512 0.0001028 0.005654 0.0001028 0.0057568 0.0001028 0.0058596 0.0001028 0.0059624 0.0001028 0.0060652 0.0001028 0.006168 0.0001028 0.0062708 0.0001028 0.0063736 0.0001028 0.0064764 0.0001028 0.0065792 0.0001028 0.006682 0.0001028 0.0067848 0.0001028 0.0068876 0.0001028 0.0069904 0.0001028 0.0070932 0.0001028 0.007196 0.0001028 0.0072988 0.0001028 // last one dumped Code:
FoamFile { version 2.0; format ascii; class dictionary; location "0.0072988/uniform"; object time; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // value 0.00729879999999991612; // this value looks weired name "0.0072988"; index 710; deltaT 1.028e-05; // same value as that in controlDict deltaT0 1.028e-05; // same value ... but in scientific format |
August 8, 2020, 02:34 |
#30 |
After posting, I just found I changed the endTime during the run incorrectly which made the endTime not a multiple of writeInterval though it is a multiple of deltaT. That's why the data were not outputed.
Sorry about that! |
Feature Capture Problem | brunob | ANSYS Meshing & Geometry | 0 | July 21, 2011 05:17 |
Meshing related issue in Flow EFD | appu | FloEFD, FloWorks & FloTHERM | 1 | May 22, 2011 09:27 |
for developers: bug or feature? | akarak | Siemens | 0 | October 22, 2009 03:47 |
Maybe a bug in CFX12.0 BETA? | frank | CFX | 4 | November 26, 2008 19:08 |
Bug or a feature of OF15 | rafal | OpenFOAM Bugs | 5 | July 25, 2008 06:25 |
