Problem using AMI
Like Tree69Likes
Old   May 8, 2012, 08:23
kid
cfdkid
kid is on a distinguished road
Hello Everyone,
Have been stuck with AMI implementation for some time now and require some help guys.
Review of Problem: trying to solve rotating square in regular fluid domain.
Case file here: http://db.tt/59ubLm1j
Error: See after few iteration the delta T becomes irrelevant ( controlDict) and solver selects depending on courent number i suppose do not know why?
Note 1: "NAN" is last value that solver gets and stops.
GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 50
time step continuity errors : sum local = nan, global = nan, cumulative = -nan
PIMPLE: iteration 2
smoothSolver: Solving for Ux, Initial residual = nan, Final residual = nan, No Iterations 1000
smoothSolver: Solving for Uz, Initial residual = nan, Final residual = nan, No Iterations 1000
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar, found on line 3 the word 'nan'
file: /home/chandra/OpenFOAM/chandra-2.1.x/run/roCube/system/data::solverPerformance::U at line 3.
From function operator>>(Istream&, Scalar&)
in file lnInclude/Scalar.C at line 91.
FOAM exiting
Note 2: If you see the AMI line i.e this line . We see 0 source face and 0 target faces. Is it right or wrong ? Really no idea.
I thought some faces should be there to transfer values.
.AMI: Creating addressing and weights between 0 source faces and 0 target faces
Any idea people, ?????
Commands i executed.
1.blockMeah
2 snappyHexMesh
3 mergeMeshes rotor/ stator/ (above 2 steps were repeated separately for rotar and stator.)
4 topoSets
5 ChangeDirectory
6 pimpleDyFoam
________________________________________
Regards,
CFDkid
It never gets easier You just get Better
kid is offline   Reply With Quote
Old   May 8, 2012, 23:16
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Look in your boundary file
    AMI1_patch0
        type            cyclicAMI;
        nFaces          0;
        startFace       23605;
        matchTolerance  0.0001;
        neighbourPatch  AMI2_patch0;
        transform       noOrdering;
    AMI2_patch0
        type            cyclicAMI;
        nFaces          0;
        startFace       23605;
        neighbourPatch  AMI1_patch0;
both AMIs has 0 faces
also your changeDictionary
dictionaryReplacement
    boundary
        AMI1_patch0
            type            cyclicAMI;
            nFaces          0;
            startFace       24985;
            surface
        AMI2_patch0
            type            cyclicAMI;
            nFaces          0;
            startFace       24985;
            surface
here you set both to have the same startface and 0 nFaces, if I where you I would not use changeDictionary as it obviously does not do what you think it does. Change the files manually.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   May 9, 2012, 02:00
kid
cfdkid
Hi linnemann,
Thank you for reply.
Same case after modification you suggested is here:
http://dl.dropbox.com/u/70019943/roCube2.tar.gz
Yes you are right i do not need changeDict file (silly on my part even after understanding i tried to use it as it made Solver to run ). Now when i change manually :
splitMeshRegions -makeCellZones -overwrite
This gives error as under.
Now the good part is this "weights between 1380 source faces and 1504 target".
Is there something i am terribly missing????
HTML Code:
Reading volScalarField cellToRegion
Reading volScalarField p
AMI: Creating addressing and weights between 1380 source faces and 1504 target faces
--> FOAM FATAL ERROR:
Unable to set source and target faces
    From function void Foam::cyclicAMIPolyPatch::setNextFaces(label&, label&, const primitivePatch&, const primitivePatch&, const boolList&, labelList&, const DynamicList<label>&) const
    in file lnInclude/AMIInterpolation.C at line 878.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/home/chandra/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
Regards,
CFDkid
Old   May 9, 2012, 03:53
linnemann's Avatar
Niels Nielsen
If you had spent just 2min on viewing the case in paraview and enabling the two AMIs like in the screenshot you will see why you have an error.
Linnemann
Old   May 9, 2012, 04:04
kid
cfdkid
Sir ,
Is it because of tooth edges on AMI1_patch0.
Really sorry if this question is too trivial.
Regards,
CFDkid
Old   May 9, 2012, 04:38
linnemann's Avatar
Niels Nielsen
also that, but also because one of the sides of the AMI contains the top and bottom faces.
The ami should be 1:1 geometry wise, not mesh, but the extend and size must be the same.
fisichel and amuzeshi like this.
Linnemann
Old   May 9, 2012, 04:46
kid
cfdkid
Sir,
" because one of the sides of the AMI contains the top and bottom faces"
This is not clearly understood by me. Could you elaborate?
Also geometry should be 1:1 . What this means ?
Regards,
CFDkid
Old   May 9, 2012, 05:00
linnemann's Avatar
Niels Nielsen
The regions on each side of the AMI Connections are not allowed to be of different sizes and have non-overlap regions.
Linnemann
Old   May 9, 2012, 05:15
kid
cfdkid
Well AMI1_patch0 is a cylindrical mesh with square. ( this will have upper and lower faces)
And AMI2_patch0 is the other one that is a hollow cylinder with no top and bottom surface.
If not his way what should be the logic to implement both AMI Sir?
Or any other pointer?
Or If we forget all doubts above . What should be the expected look in paraview on selecting both AMI patchs?
Regards,
CFDkid
Old   May 9, 2012, 08:05
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Hi Foamers,
have you tried AMI rotating things using unstructured tetrahedral mesh? In my case I have to use it due to the complexity of my geometry, but I have convergence problems (blowing up pressure fields).
Best,
A
I am doing CFD Consulting Services.
Ich biete CFD Strömungssimulationen an.
Attesz is offline   Reply With Quote
Old   May 9, 2012, 08:50
kid
cfdkid
Hello Attesz,
What tool you used for generating unstructured Mesh? Any OpenSource tool??
Regards,
CFDkid
Old   May 9, 2012, 08:51
Attesz's Avatar
Attesz
Originally Posted by kid View Post
Hello Attesz,
Hi, no, i'm using ICEM CFD.
Old   May 9, 2012, 23:02
linnemann's Avatar
Niels Nielsen
In your case both the AMI's have to be a hollow cylinder with no top and bottom
Linnemann
Old   May 12, 2012, 01:57
Jason Eason
JulytoNovember is on a distinguished road
Linneman, what would you suggest to do with the top and bottom? Inlets and outlets or would you change the nfaces to 0? Or would you suggest something else?
Debian Squeeze - OpenFOAM-2.1.x, Paraview-3.12.0
JulytoNovember is offline   Reply With Quote
Old   May 23, 2012, 15:57
Default Bugreport, please contribute
  #95
Attesz's Avatar
Attesz
Dear all,
I've just created a bugreport on OpenFOAM Mantis (http://www.openfoam.org/bugs/) issue 0000539 in this topic (AMI weight goes down to 0).
Please contribute with your observations to solve this bug asap.
Best regards,
Attesz
Originally Posted by vinz View Post
Dear all,
It's been a while since I did not post on the forum, but I am still following with attention the new developments.
I tried to use the AMI feature with pimpleDymFoam on the tutorial propeller. It works perfectly and look very promising.
So I decided I would try it on one of my own model, and see what I get. Unfortunately, it always break up at some point whatever I use for the max courant number, or the relaxation factors, or many different things I tried.
I just notice that the last time step writes the following lines:
solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.00123617 transformation: ((0 0 0) (0.981207 (0 0 0.192959)))
AMI: Creating addressing and weights between 23366 source faces and 23366 target faces
AMI: Patch source weights min/max/average = 0.000261522, 1.75988, 1.00123
AMI: Patch target weights min/max/average = 0, 1.3569, 1.00084
PIMPLE: iteration 1
I guess now the problem is coming from the "0" we can see just above. Am I right? What does it exactly means? and how can I solve this problem?
Thanks in advance for your advice.
Old   May 24, 2012, 01:36
kid
cfdkid
Hi Attesz,
Its good that you have reported this issue.
Also in my case it is lack of my understanding of AMI that is creating problem, i suppose.
Attesz likes this.
Regards,
CFDkid
Old   May 24, 2012, 03:19
stephane sanchi
openfoam_user is on a distinguished road
Hi Attesz,
Now for me it works but only when I generate the grid with ICEMCFD Hexa.
When I generate the mesh with snappyHexMesh (like propeller tutorial) it crashes. Same error as you. Strange because residuals and convergence history is smooth until the crash.
I hope that the AMI robustness will be improved.
Regards,
Stephane
Attesz likes this.
openfoam_user is offline   Reply With Quote
Old   May 24, 2012, 07:01
Alexander Tagirov
Randomizer is on a distinguished road
Hi Attesz,
I've had a lot of trouble with the same issue you posted. You see, when AMI gets zero weights, that means that during the interpolation to one of the faces on one AMI patch it couldn't find any faces on second AMI patch that has a projection to this face. The reason for this could be a bug in search/interpolation algorithm, or not a very good mesh. The AMI patches should be as much identical as possible (I mean the mesh, because geometry should be totally the same) , especially if they are cylindrical.
Randomizer is offline   Reply With Quote
Old   May 24, 2012, 07:08
kid
cfdkid
Hi All,
SUccess after almost 2 months in using AMI.
Though i used "SALOME" mesh imported in OpenFOAM-21x.
Also results are not good!!
But the weights are getting transfered though. Something like this.
AMI: Patch source weights min/max/average = 0.965339, 1.1551, 1.00005
AMI: Patch target weights min/max/average = 0.996065, 1.02292, 1.00278
Next step would be improving mesh again. Thanks everyone specially "linnemann" stephane and lovecraft. And you also guys.
Regards,
CFDkid
Old   May 24, 2012, 08:52
Attesz's Avatar
Attesz
Ok but how did you manage to make it work?
Hi All,
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
