Problem using AMI
Like Tree69Likes
Old   April 25, 2012, 04:44
stephane sanchi
openfoam_user is on a distinguished road
Dear all,
I have uploaded on our website page dedicated to OpenFOAM applications some pictures and movies done using pimpleDyMFoam and AMI capabilities.
http://www.cfse.ch/cfse/site/openfoam.php
Regards,
Stephane.
linnemann, gohome, chun and 2 others like this.
openfoam_user is offline   Reply With Quote
Old   April 25, 2012, 04:47
kid
cfdkid
kid is on a distinguished road
Thank you for this i am stuck from past few weeks, rotating a cube in regular domain.
Link here:
http://www.cfd-online.com/Forums/ope...tml#post356808
Now, will take a break and see, what you have suggested.
________________________________________
Regards,
CFDkid
It never gets easier You just get Better
kid is offline   Reply With Quote
Old   April 25, 2012, 04:52
stephane sanchi
Hi CFDkid,
I have reproduced exactly the propeller tutorial:
~/OpenFOAM-2.1.x/tutorials/incompressible/pimpleDyMFoam/propeller/
Using blockMesh and snappyHexMesh my case blows.
Using ICEM Hexa for generating the grid the case runs fine.
Regards,
Stephane.
Old   April 25, 2012, 04:58
kid
cfdkid
Good man.
For me ICEM not available. So need to work around sHM or Solome.
Have look at my case in spare time. ( link is in my previous post)
Regards,
CFDkid
Old   April 25, 2012, 11:16
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Originally Posted by openfoam_user View Post
Good stuff Stephane.
Really like that you have shared your endeavors :-)
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   April 25, 2012, 23:35
liping_he
liping_he is on a distinguished road
hi Stephane
I am sorry for my question, but i have no idea about it. This question is also about mesh generation. I have used ICEMCFD to generate mesh with 2 fluid parts and 1 interface between rotoring and moving parts. I have convert the mesh with fluent3DMeshToFoam. The mesh only has ONE FACE (interface mentioned above) patch in AMI1. How can i acquire another face to patch in AMI2. Thanks..
Regards,
he
liping_he is offline   Reply With Quote
Old   April 26, 2012, 03:08
stephane sanchi
With ICEM Hexa I have ONLY one fluid part. Export in V6 fluent format. Then use the fluent3DMeshToFoam command to convert the mesh.
Try to follow exactly the propeller tutorial. Keep the same names (boundaries, zones, ...). Use the topoSet command to generate face/cell sets and zones (like in the tutorial).
Regards,
Stephane.
Old   April 26, 2012, 06:00
liping_he
Hello Stephane.
How to obtain the ID of startFace in changeDictionaryDict file in propeller tutorial
Regards,
liping
Old   April 26, 2012, 06:18
stephane sanchi
(1) Open your constant/polyMesh/boundary file.
(2) Compute nFaces + startFace of your last boundary.
(3) Open your changeDictionaryDict file.
(4) startFace (for AMI1 and AMI2) = result computed in (2)
Regards,
Stephane.
Old   April 27, 2012, 07:58
liping_he
Hi Stephane.
Thanks for your help. For now, following the propeller tutorial I can genarate the AMI1 and AMI2 faces. but the faces are coarse and toothed. look at the picture attached. I have no idea about this issue...
Thanks in advance,
liping
Old   April 27, 2012, 08:16
stephane sanchi
no pictures attached.
Stephane.
Old   April 27, 2012, 23:16
liping_he
HI, Stephane
SORRY..HERE IS THE PICTURE
Old   April 28, 2012, 06:22
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Are you looking at the correct time step?
lovecraft22 is offline   Reply With Quote
Old   April 30, 2012, 03:25
stephane sanchi
Hi he,
The grid doesn't seem to be generated using ICEM Hexa !
You will have problems at the interface between the rotating and the static domains.
Your interface has to be smooth (circle).
See the picture. The pink line is the interface between the rotating and the static parts.
Regards,
Stephane.
Old   May 1, 2012, 21:47
liping_he
Hi Stephane, lovercraft22
Thanks for your reply. I have know the reason why the AMI1/2 faces show coarse and toothed.
1, the mesh is not generated using circular grid.
2, I should have retained the interface (the AMI1/2 face ) when I created mesh. The createAMIFaces.topoSetDict file can not split grid. It only can create AMI1/2 faces on the basis of original mesh we generated.
Regards,
he
Old   May 2, 2012, 06:56
kid
cfdkid
Hi stephane,
Does OpenFOAM-210 and OpenFOAM-21x make any difference for implementing AMI feature?
I meant is there any advantage or improvement .
Regards,
CFDkid
Old   May 2, 2012, 07:07
stephane sanchi
I use OpenFOAM latest git version (OF-2.1.x).
AMI is implemented in OF-2.1.x.
See ~/OpenFOAM-2.1.x/tutorials/incompressible/pimpleDyMFoam/propeller tutorial.
Stephane.
Old   May 3, 2012, 01:51
kid
cfdkid
Stephane,
Thanks, so that means if we intend to implement AMI, OpenFOAM-21X has to be used.
Actually, while i try to model a problem using AMI in OpenFOAM-210, it throws error. It could be because of my less understanding of it too. But could the version 210 instead of 21x be the culprit too?
Regards,
CFDkid
Old   May 3, 2012, 03:12
stephane sanchi
AMI is already implemented in OF-2.1.x.
My case crashes too, except when I use ICEM (fully structured grid) for grid generation.
Regards,
Stephane.
Old   May 3, 2012, 04:05
kid
cfdkid
Ok Stephane thanks.
Going to upgrade OF210 to OF21x. Hope to see some improvement.
Regards,
CFDkid
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
