OF 2.1.0 Symmetry BC Problem
Old   December 28, 2011, 12:29
Default OF 2.1.0 Symmetry BC Problem
plm
RW
plm is on a distinguished road
Hi all,
After recently updating to OpenFOAM 2.1.0 I'm recieving an error when I try to run cases in which I use a symmetrical boundary condition......
The error I get is "essential value entry not provided"
Here is an extract from the boundary conditions file where the error is being called:
symmetry
type symmetryPlane;
I don't know what "value" OF is looking for......
Any help greatly appreciated, thanks for your time.
plm
plm is offline   Reply With Quote
Old   December 28, 2011, 20:22
Matthew Denno
mgdenno is on a distinguished road
Unfortunately I don't have any real suggestions, but it seems to be working fine for me. I haven't specified a value for "value" How is it specified in constant/polyMesh/boundary?
MD
mgdenno is offline   Reply With Quote
Old   December 29, 2011, 06:22
plm
RW
Hey MD, cheers for your reply
It's specifiesymmetry
type symmetryPlane;
nFaces 5080;
startFace 498840;
d as normal, with type symmetryPlane....
One thing I don't really understand is that for the symmetry bc's on velocity and pressure, there isn't a problem .... it only works for phi.
It seems however that the problem is solved if I delete the phi fields for all time and recalculate them.
plm
Old   April 5, 2012, 02:51
prasanth
prasanth is on a distinguished road
Hello plm,
I am also facing the same issue. Previously I used OF-2.0.1. If I am using OF-2.1.0, I am getting the same error which you have mentioned. Do we need to delete the "phi" file and recalculate again? if we do like this means, past data may lose. Am I correct? Or do you find any other way? If So, please reply.
Regards
Prasanth.
prasanth is offline   Reply With Quote
Old   April 5, 2012, 11:17
Mihai Pruna
mihaipruna is on a distinguished road
Originally Posted by plm View Post
Hi all,
plm
In Blockmeshdict this is what I use:
leftZmin
type symmetryPlane;
faces
(4 5 6 7)
I also have a file which defines patches which is used by the initial flow variable dictionaries omega,p etc.. and there I have this:
leftZmin
type symmetryPlane;
Mihai Pruna's Bio
mihaipruna is offline   Reply With Quote
Old   April 6, 2012, 04:04
prasanth
Hello mihai,
symmetryPlane boundary condition is working fine when I am using OF-2.0.1. But the same case, If I want to continue in OF-2.1.0 means, Its giving strange errors like "essential value entry not provided".
But if we follow the same approach in OF-2.1.0 from scratch means, its works fine here too.
Regards
Prasanth.
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
Symmetry problem sameer10dulkar FLOW-3D 5 January 21, 2011 15:11
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 06:29
Symmetry plane error in solver Santiago Orrego. CFX 6 January 31, 2007 08:09
problem with Symmetry boundary condition Miri FLUENT 1 November 15, 2006 14:09
