Total pressure BC with simple foam
Old   December 24, 2011, 16:38
Default Total pressure BC with simple foam
duri
duri is on a distinguished road
I am trying out fluent's MRF tutorial in MRFSimpleFoam. For inlet BC I used total pressure bc where i could preserve my inlet total pressure. While running it shown some error that volScalarField rho not found. So, i removed rho and psi field from total pressure BC.
Now solver is starting the iteration but pressure and velocity became completely unbounded.
My BC's are,
inlet : total pressure fixed to 200
velocity zeroGradient
outlet : pressure fixedValue to 0
Please help me in setting up inlet bc.
One more doubt, do i need to include surface names that rotate along with rotating zone in nonrotatingpatch () in MRFZone file.
Thanks
duri is offline   Reply With Quote
Old   March 20, 2012, 09:05
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
did you find answer for your problem? I want to use the same boundary conditions like you, was it stable?
Thanks
I am doing CFD Consulting Services.
Ich biete CFD Strömungssimulationen an.
Attesz is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 11:08
Total pressure in CFX famarcfd CFX 0 June 17, 2011 11:33
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Total pressure in a laval nozzle Sohail Ahmed FLUENT 0 May 19, 2004 06:28
