motorBIke Tutorial runs with kEpsilon but not with relizableKE
Old   December 13, 2011, 08:53
Default motorBIke Tutorial runs with kEpsilon but not with relizableKE
BastiL
bastil is on a distinguished road
Dear all,
I get an error when I try to run the Motorbike-tutorial in 2.0.x using the realizableKE Turbulence Modell. Everything runs fine with kEpsilon:
Time = 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0709814, No Iterations 3
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.0693559, No Iterations 3
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.063382, No Iterations 3
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.0613634, No Iterations 3
time step continuity errors : sum local = 0.00536085, global = 2.57043e-05, cumulative = 2.57043e-05
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#1  Foam::sigSegv::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#2  ?? in "/lib64/libc.so.6"
#3  Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64Gcc45DPOpt/lib/libincompressibleRASModels.so"
#4  Foam::incompressible::RASModels::realizableKE::correct() in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64Gcc45DPOpt/lib/libincompressibleRASModels.so"
#5  main in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64Gcc45DPOpt/bin/simpleFoam"
#6  __libc_start_main in "/lib64/libc.so.6"
#7  __gxx_personality_v0 in "/opt/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64Gcc45DPOpt/bin/simpleFoam"
Segmentation fault
Ideas?
Thanks Bastian
Edit: I found a bug for that: http://www.openfoam.com/mantisbt/view.php?id=307
bastil is offline   Reply With Quote
[snappyHexMesh] Trying to understand the motorBike tutorial Andyjoe OpenFOAM Meshing & Mesh Conversion 10 August 10, 2014 17:57
Wrong file in motorBike tutorial? lovecraft22 OpenFOAM 3 August 4, 2011 14:03
Basic question on motorBike tutorial newToOpenFoam OpenFOAM Running, Solving & CFD 2 July 14, 2011 10:50
motorBike tutorial and Scaling - New geometry used, scaled and now large velocity!!! scott OpenFOAM 1 July 29, 2010 05:09
InletOutlet boundary condition in motorBike tutorial madad2005 OpenFOAM 2 November 27, 2009 09:15
