December 7, 2011, 08:23 |
courant number explodes with pisoFoam solver
I'm trying to simulate the unsteady flow arround a cylinder with a velocity inlet of 17 m/s. I'm using a pisoFoam solver with a RAS kEpsilon turbulent model. When I run the simulation the courant numbre explodes. Time = 5e-05 Courant Number mean: 4.53303e+07 max: 1.0204e+12 DILUPBiCG: Solving for Ux, Initial residual = 0.985101, Final residual = 9.2599e-06, No Iterations 389 DILUPBiCG: Solving for Uy, Initial residual = 0.735666, Final residual = 0.188579, No Iterations 1001 DICPCG: Solving for p, Initial residual = 1, Final residual = 12.4404, No Iterations 1001 time step continuity errors : sum local = 4.28628e+29, global = -1.82086e+27, cumulative = -1.82086e+27 DICPCG: Solving for p, Initial residual = 0.582249, Final residual = 18.1122, No Iterations 1001 time step continuity errors : sum local = 2.2474e+41, global = -6.08311e+32, cumulative = -6.08312e+32 DICPCG: Solving for p, Initial residual = 0.940306, Final residual = 3.70065, No Iterations 1001 time step continuity errors : sum local = 1.08796e+43, global = 1.37468e+36, cumulative = 1.37407e+36 #0 Foam::error:rintStack(Foam::Ostream&) in "/apl/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/apl/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so" #2 __restore_rt at sigaction.c:0 #3 Foam::LimitedScheme<double, Foam::limitedLinearLimiter<Foam::NVDTVD>, Foam::limitFuncs::magSqr>::limiter(Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/apl/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64Gcc45DPOpt/lib/libfiniteVolume.so" #4 Foam::limitedSurfaceInterpolationScheme<double>::w eights(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/apl/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64Gcc45DPOpt/lib/libfiniteVolume.so" #5 Foam::fv::gaussConvectionScheme<double>::fvmDiv(Fo am::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/apl/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64Gcc45DPOpt/lib/libfiniteVolume.so" #6 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double , Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "/apl/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64Gcc45DPOpt/lib/libincompressibleRASModels.so" #7 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double , Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/apl/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64Gcc45DPOpt/lib/libincompressibleRASModels.so" #8 Foam::incompressible::RASModels::kEpsilon::correct () in "/apl/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64Gcc45DPOpt/lib/libincompressibleRASModels.so" #9 main in "/apl/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64Gcc45DPOpt/bin/pisoFoam" #10 __libc_start_main in "/lib64/libc.so.6" #11 Foam::UOPstream::write(char) in "/apl/OpenFOAM/OpenFOAM-2.0.0/platforms/linux64Gcc45DPOpt/bin/pisoFoam" Floating exception I've tried to decrease the deltaT but it doesn't work. I also changed the nNonOrthogonalCorrectors and the ddtSchemes If I run the simulation without a turbulent model it works. I tried to modify the boundaryField but i cannot find out the problem. I'm just learning to use openfoam so it may be a basic problem that i cannot see. I couldn't upload the geometry files since it's too large. Thanks for your help Best regards |
December 8, 2011, 04:53 |
Suresh kumar Kannan
Rep Power: 17 |
HI ,
Just a suggestion run a checkMesh and see if your aspect ratio and Non-orthogonality checks are ok. It may also be caused due to the non-appropriate boundary conditions. So if you give some details about the boundary conditions. May be some one can help. regards K.SUresh kumar |
December 8, 2011, 05:32 |
Rob
Rep Power: 15 |
@kumar: He attached his case in a .zip file
@tol24: By having a quick look at your files I assume that your BC's for the symmetryPlane are wrong. The wallfunctions might not be the problem. But having a look at your "U" file you can see that you assigned 17 m/s on your symmetryPlane. So even if you treat your symmetryPlane like a wall this is not correct! If the "fix(es)" don't help maybe you should give simpleFoam a try. |
December 9, 2011, 07:57 |
Thanks, for helping!
@kumar: I did check mesh and it was ok @robbirobocop: yes, I thought it could be that, but actually I want to simulate the cylinder in a freestream and not between two walls. How could I do that? If I fix the velocity to zero it will generate a boundary layer arround the limits, doesn't it? |
August 19, 2013, 05:19 |
X Meng
Rep Power: 14 |
I have the nearly exactly same trouble now.
Newbie Question IcoFoam - Courant Number explodes | sprobst76 | OpenFOAM Running, Solving & CFD | 12 | March 1, 2018 08:35 |
mach number and selection of the fluent solver | turbinesv | FLUENT | 4 | April 24, 2011 01:14 |
Courant number | songpen1985 | FLUENT | 0 | April 17, 2009 04:45 |
LES near wall model & courant number | kasim | CFX | 5 | March 16, 2008 19:23 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
