OpenFoam/FLUENT difference in cilinder case
Old   December 7, 2011, 07:41
Talking OpenFoam/FLUENT difference in cilinder case
Rui Vizinho de Oliveira
RuiVO is on a distinguished road
Good day to you all,
I am running the same case file in OpenFoam and in Fluent, with the most similar Boundary Conditions possible. The problem is that pressure field is similar but velocities are totally different, almost 3 times less in OpenFoam. I do not know what the problem is, I have not attached the Fluent Case file since it is too large. I have however attached files of the OpenFoam case. God I love the maximum size of 97 kb for file attach
Just a heads up of what I have done:
OpenFoam case is run using rhoSimpleFoam solver in laminar regime with total pressure inlet of 4907 and fixed pressure outlet of 3877. The converged inlet velocity is about 38 to 40 m/s.
Fluent case is runned on a pressure based solver, laminar regime with same boundary conditions and the converged velocity inlet is about 140 m/s.
To my knowledge, both solutions have converged.
0.zip
system.zip
constant.zip
case_geom.pdf
Best Regards
Rui Oliveira
RuiVO is offline   Reply With Quote
Old   December 11, 2011, 20:44
Jacques
jackpap is on a distinguished road
Are you sure your viscosities and densities are set in the same way?
Also in Fluent are you sure you are comparing the right pressures and that you don't have an offset / "Operating pressure" ?
jackpap is offline   Reply With Quote
Old   December 12, 2011, 15:26
Hi jackpap ! Yes . Anyway I have solved the problem ! Now I use rhoPisoFoam with total pressure boundary condition at the inlet as before, but !!! now I assing the following change (boundary conditions are not exact, cant remember the name of exact term since I dont have the file at hand now but you get the picture):
inlet
type totalPressure
p0 4907
value 3877
rho rho /*THIS IS WHAT IS MISSING !!!!*/
After I changed the boundary conditions at inlet ... problem solved
Best regards
Rui Oliveira
Error reading new case montag dp FLUENT 5 September 15, 2011 07:00
Instable natural convection case Peter88 OpenFOAM 5 August 18, 2011 02:23
Interfoam Droplet under shear test case adona058 OpenFOAM Running, Solving & CFD 3 May 3, 2010 19:46
Cloning a case or creating a new case for 16 processes mellanoxuser OpenFOAM Running, Solving & CFD 0 February 8, 2008 17:52
How to save a case running in background us FLUENT 0 July 6, 2005 11:43
