Adaptive Local Mesh Refinement
Old   May 17, 2013, 05:53
RJ HO
RJ87 is on a distinguished road
Originally Posted by kalle View Post
Thanks for your answer! I dug a bit further to pinpoint the issue... it was rather easy to locate it, so I do not know why they did not respond. Either a nice fix is less easy to come up with, or this is actually not a bug, but rather me making studpid errors...
K
I have the exact same problem like yours. What's the problem exactly?
RJ87 is offline   Reply With Quote
Old   July 24, 2013, 02:18
conceptone is on a distinguished road
Hi Marco,
I use OF 2.1.1 so I need to modify some codes in the very fundamental library-"OpenFoam", which mentioned in the bug report. However, since we use cluster servers here, no matter how I try to modify the Make/option file, it always reads the original "OpenFoam" library, which outputs like below when compiling:
-I/usr/apps1/openfoam-2.1.1/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/usr/apps1/openfoam-2.1.1/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude
so it doesn't recognize the codes I changed. It only appears for the library "OpenFoam", not for other libraries, I guess the reason is that it's the cornerstone, and I am sure I didn't make mistakes in Make/option and Make/files. So do you have idea about this problem?
Thanks!
conceptone is offline   Reply With Quote
Old   July 24, 2013, 13:16
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Can you post your Make/options file? Also, what are the values of the following system variables:
$FOAM_SRC
$FOAM_LIBBIN
$FOAM_USER_LIBBIN
mturcios777 is offline   Reply With Quote
Old   July 25, 2013, 03:09
Thanks for reply,Macro. I guess the problem is not from Make/options in the library named "OpenFoam", for I have already deleted all codes in this file, which means it shouldn't read other libraries or utilities, but I still got the message like above I attached when I compile the library named "OpenFoam". So I can expect same situation for other libraries, which means it would not read the modifies codes in like polyMeshClear.C.
So I have installed the OpenFoam on my personal laptop in Ubuntu system, in this case I guess I can get the biggest permission. However, after I use the command"src", then I reach the source libraries:/opt/OpenFoam-2.1.1/src, and found I can't modify codes there. But if I compile libraries under $WM_PROJECT_DIR, then the libraries will still read -I/opt/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude, which is the same thing as I use in the cluster server.
It seems that you use your personal computer for OpenFoam, then could you tell me how to make it read the modified "OpenFoam" library but not read the original library named "OpenFoam" for my laptop? Is it like I should change some codes in some file, then I can modify codes under /opt/OpenFoam/src (after I use command "src" I reach here)directory?
Thanks
Old   July 25, 2013, 13:15
Marco A. Turcios
If you are going to make changes to the base OpenFOAM install (which really don't recommend), I would install either the source pack and compiler everything from scratch (in the $HOME/OpenFOAM/OpenFOAM-2.1.1 directory) or the GIT repository that always gets you the latest updates. Having OpenFOAM in the /usr or /opt directories makes effecting change to the base code messy. What were the values of the system variables I asked about?
Old   September 23, 2013, 06:33
Default Trouble with dieselDyMFoam in OF20x
  #26
Ah Cai
ahcai007 is on a distinguished road
Originally Posted by Abhishekd18 View Post
I am trying to run dieselDyMFoam with adaptive local mesh refinement. I getting following error. Can anyone help?
Thanks.
Evolving Spray
Selected 66616 cells for refinement out of 68700.
Refined from 68700 to 535012 cells.
--> FOAM FATAL ERROR:
Not implemented
From function cloud::autoMap(const mapPolyMesh&)
in file fields/cloud/cloud.C at line 65.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so"
#2 Foam::mapClouds(Foam:bjectRegistry const&, Foam::mapPolyMesh const&) in "/opt/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc46DPOpt/lib/libfiniteVolume.so"
#3 Foam::fvMesh::mapFields(Foam::mapPolyMesh const&) in "/opt/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc46DPOpt/lib/libfiniteVolume.so"
#4 Foam::fvMesh::updateMesh(Foam::mapPolyMesh const&) in "/opt/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc46DPOpt/lib/libfiniteVolume.so"
#5 Foam::dynamicRefineFvMesh::refine(Foam::List<int> const&) in "/opt/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc46DPOpt/lib/libdynamicFvMesh.so"
#6 Foam::dynamicRefineFvMesh::update() in "/opt/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc46DPOpt/lib/libdynamicFvMesh.so"
#7 main in "/opt/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc46DPOpt/bin/dieselDyMFoam"
#8 __libc_start_main in "/lib64/libc.so.6"
#9 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc46DPOpt/bin/dieselDyMFoam"
Aborted
Originally Posted by mturcios777 View Post
For those who follow this thread, the issue with lagrangian mapping has been solved and now works wonderfully in 2.1.x!
I am currently having the same error as mentioned by Abhishek when running adaptive local mesh refinement for dieselDyMFoam in OF20x. According to Marco, the problem has been resolved and it works just fine in OF21x.
However, I really would like to stick to OF20x as I have ran lots of simulation cases in OF20x and would like to be consistent in the OF version I am using.
Is there a way to proceed with mesh refinement in OF20x or there is no other way except to switch versions?
Thanks.
Regards,
Ahcai
ahcai007 is offline   Reply With Quote
Old   March 31, 2015, 09:19
MürgoHaw's Avatar
Haw
MürgoHaw is on a distinguished road
i tried to apply the automatic mesh refinement in SprayFoam.
For this i got much help from this Thread: http://www.openfoam.org/mantisbt/view.php?id=464
So far it seems the new solver has no errors itself.
Unfortunately i got this error in the compiling process. I think its a problem with the platform:
-lfiniteVolume -lmeshTools -lcompressibleTurbulenceModel -lcompressibleRASModels -lcompressibleLESModels -llagrangian -llagrangianIntermediate -llagrangianSpray -lspecie -lbasicThermophysicalModels -lliquidProperties -lliquidMixtureProperties -lsolidProperties -lsolidMixtureProperties -lthermophysicalFunctions -lreactionThermophysicalModels -lSLGThermo -lchemistryModel -lradiationModels -lODE -lregionModels -lsurfaceFilmModels -lsampling -ldynamicFvMesh -ltopoChangerFvMesh -ldistributionModels -lOpenFOAM -ldl -lm -o /cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/bin/dynamicSprayFoam
/usr/bin/ld: warning: libmpi.so.1, needed by /cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so, not found (try using -rpath or -rpath-link)
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Waitall'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Abort'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `ompi_mpi_double'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Get_count'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Init'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Probe'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Send'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Allreduce'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `ompi_mpi_packed'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Buffer_detach'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Bsend'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `ompi_mpi_byte'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Irecv'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Recv'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `ompi_mpi_comm_world'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Get_processor_name'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Test'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Isend'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Finalize'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `ompi_mpi_op_sum'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Buffer_attach'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Comm_size'
/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so: undefined reference to `MPI_Comm_rank'
collect2: ld returned 1 exit status
make: *** [/cax/sw/OPENFOAM/LINUX_x86_64/moa1/milano/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/bin/dynamicSprayFoam] Error 1
Can anyone help me? Thank you very much!
MürgoHaw is offline   Reply With Quote
[Technical] Local adaptive mesh refinement with hybrid meshes holger_marschall OpenFOAM Meshing & Mesh Conversion 5 December 21, 2010 14:38
Adaptive Mesh Refinement and Cyclic Boundary Conditions adona058 OpenFOAM Running, Solving & CFD 6 October 23, 2009 10:17
basic of mesh refinement arya CFX 4 June 19, 2007 13:21
Mesh Refinement JY Siemens 7 September 19, 2002 14:37
Hints on adaptive mesh refinement Bo Jensen Siemens 0 July 17, 2000 09:39
