DeardorffDiffStress turbulence model
Old   November 14, 2011, 09:44
Default DeardorffDiffStress turbulence model
Tom Schmitz
Zuixy is on a distinguished road
Hey,
I'm using PisoFoam with the DeardorffDiffStress turbulence model to calculate some air flow but i get an error.
addr2line failed
[2] #1 Foam::sigFpe::sigHandler(int) addr2line failed
[4] #1 Foam::sigFpe::sigHandler(int) addr2line failed
[5] #1 Foam::sigFpe::sigHandler(int) addr2line failed
[2] #2 addr2line failed
[3] addr2line failed
[5] #2 #1 Foam::sigFpe::sigHandler(int)Uninterpreted: /lib64/libc.so.6 addr2line failedUninterpreted: /lib64/libc.so.6
[4] #2 addr2line failed
[2] #3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) addr2line failed
[3] # addr2line failed
[2] #42 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) addr2line failed
[5] #3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) addr2line failed
Uninterpreted: /lib64/libc.so.6 [2] #Uninterpreted: /lib64/libc.so.6 5 Foam::incompressible::LESModels:eardorffDiffStre ss::correct(Foam::tmp<Foam::GeometricField<Foam::T ensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) addr2line failed
[5] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) addr2line failed
addr2line failed
[4] #3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&)[2] #6 Foam::incompressible::LESModel::correct() addr2line failed
[3] #3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) addr2line failed
[2] #7 addr2line failed
[4] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) addr2line failed
[3] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&)Uninterpreted: pisoFoam
[2] #8 __libc_start_main addr2line failed
[4] #5 Foam::incompressible::LESModels:eardorffDiffStre ss::correct(Foam::tmp<Foam::GeometricField<Foam::T ensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) addr2line failed
[2] #9 addr2line failed
[3] #5 Foam::incompressible::LESModels:eardorffDiffStre ss::correct(Foam::tmp<Foam::GeometricField<Foam::T ensor<double>, Foam::fvPatchField, Foam::volMesh> > const&)Foam::UOPstream::write(char)
[cfdl004:32593] *** Process received signal ***
[cfdl004:32593] Signal: Floating point exception (8)
[cfdl004:32593] Signal code: (-6)
[cfdl004:32593] Failing at address: 0x7a8d00007f51
addr2line failed
[5] #5 Foam::incompressible::LESModels:eardorffDiffStre ss::correct(Foam::tmp<Foam::GeometricField<Foam::T ensor<double>, Foam::fvPatchField, Foam::volMesh> > const&)[cfdl004:32593] [ 0] /lib64/libc.so.6 [0x2aaaade7c2d0]
[cfdl004:32593] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x2aaaade7c265]
[cfdl004:32593] [ 2] /lib64/libc.so.6 [0x2aaaade7c2d0]
[cfdl004:32593] [ 3] /cm/shared/apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc43DPOpt/lib/libOpenFOAM.so(_ZN4Foam4sqrtERNS_5FieldIdEERKNS_5U ListIdEE+0x26) [0x2aaaad125be6]
[cfdl004:32593] [ 4] /cm/shared/apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc43DPOpt/lib/libincompressibleRASModels.so(_ZN4Foam4sqrtINS_12f vPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFi eldIdT_T0_EEEERKS7_+0x2ce) [0x2aaaab00cf4e]
[cfdl004:32593] [ 5] /cm/shared/apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc43DPOpt/lib/libincompressibleLESModels.so(_ZN4Foam14incompress ible9LESModels19DeardorffDiffStress7correctERKNS_3 tmpINS_14GeometricFieldINS_6TensorIdEENS_12fvPatch FieldENS_7volMeshEEEEE+0x829) [0x2aaaab4e6e39]
[cfdl004:32593] [ 6] /cm/shared/apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc43DPOpt/lib/libincompressibleLESModels.so(_ZN4Foam14incompress ible8LESModel7correctEv+0x35) [0x2aaaab436485]
[cfdl004:32593] [ 7] pisoFoam [0x417e89]
[cfdl004:32593] [ 8] /lib64/libc.so.6(__libc_start_main+0xf4) [0x2aaaade69994]
[cfdl004:32593] [ 9] pisoFoam(_ZN4Foam9UOPstream5writeEc+0xa1) [0x4162c9]
[cfdl004:32593] *** End of error message ***
addr2line failed
[4] #6 Foam::incompressible::LESModel::correct() addr2line failed
[3] #6 Foam::incompressible::LESModel::correct() addr2line failed
[4] #7 addr2line failed
[3] #7 addr2line failed
[5] #6 Foam::incompressible::LESModel::correct()Uninterpr eted: pisoFoam
[4] #8 __libc_start_mainUninterpreted: pisoFoam
[3] #8 __libc_start_main addr2line failed
[5] #7 addr2line failed
[4] #9 addr2line failed
[3] #9 Foam::UOPstream::write(char)
[cfdl004:32595] *** Process received signal ***
[cfdl004:32595] Signal: Floating point exception (8)
[cfdl004:32595] Signal code: (-6)
[cfdl004:32595] Failing at address: 0x7a8d00007f53
[cfdl004:32595] [ 0] /lib64/libc.so.6 [0x2aaaade7c2d0]
[cfdl004:32595] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x2aaaade7c265]
[cfdl004:32595] [ 2] /lib64/libc.so.6 [0x2aaaade7c2d0]
[cfdl004:32595] [ 3] /cm/shared/apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc43DPOpt/lib/libOpenFOAM.so(_ZN4Foam4sqrtERNS_5FieldIdEERKNS_5U ListIdEE+0x26) [0x2aaaad125be6]
[cfdl004:32595] [ 4] /cm/shared/apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc43DPOpt/lib/libincompressibleRASModels.so(_ZN4Foam4sqrtINS_12f vPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFi eldIdT_T0_EEEERKS7_+0x2ce) [0x2aaaab00cf4e]
[cfdl004:32595] [ 5] /cm/shared/apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc43DPOpt/lib/libincompressibleLESModels.so(_ZN4Foam14incompress ible9LESModels19DeardorffDiffStress7correctERKNS_3 tmpINS_14GeometricFieldINS_6TensorIdEENS_12fvPatch FieldENS_7volMeshEEEEE+0x829) [0x2aaaab4e6e39]
[cfdl004:32595] [ 6] /cm/shared/apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc43DPOpt/lib/libincompressibleLESModels.so(_ZN4Foam14incompress ible8LESModel7correctEv+0x35) [0x2aaaab436485]
[cfdl004:32595] [ 7] pisoFoam [0x417e89]
[cfdl004:32595] [ 8] /lib64/libc.so.6(__libc_start_main+0xf4) [0x2aaaade69994]
[cfdl004:32595] [ 9] pisoFoam(_ZN4Foam9UOPstream5writeEc+0xa1) [0x4162c9]
[cfdl004:32595] *** End of error message ***
[cfdl004:32594] *** Process received signal ***
[cfdl004:32594] Signal: Floating point exception (8)
[cfdl004:32594] Signal code: (-6)
[cfdl004:32594] Failing at address: 0x7a8d00007f52
[cfdl004:32594] [ 0] /lib64/libc.so.6 [0x2aaaade7c2d0]
[cfdl004:32594] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x2aaaade7c265]
[cfdl004:32594] [ 2] /lib64/libc.so.6 [0x2aaaade7c2d0]
[cfdl004:32594] [ 3] /cm/shared/apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc43DPOpt/lib/libOpenFOAM.so(_ZN4Foam4sqrtERNS_5FieldIdEERKNS_5U ListIdEE+0x26) [0x2aaaad125be6]
[cfdl004:32594] [ 4] /cm/shared/apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc43DPOpt/lib/libincompressibleRASModels.so(_ZN4Foam4sqrtINS_12f vPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFi eldIdT_T0_EEEERKS7_+0x2ce) [0x2aaaab00cf4e]
[cfdl004:32594] [ 5] /cm/shared/apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc43DPOpt/lib/libincompressibleLESModels.so(_ZN4Foam14incompress ible9LESModels19DeardorffDiffStress7correctERKNS_3 tmpINS_14GeometricFieldINS_6TensorIdEENS_12fvPatch FieldENS_7volMeshEEEEE+0x829) [0x2aaaab4e6e39]
[cfdl004:32594] [ 6] /cm/shared/apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc43DPOpt/lib/libincompressibleLESModels.so(_ZN4Foam14incompress ible8LESModel7correctEv+0x35) [0x2aaaab436485]
[cfdl004:32594] [ 7] pisoFoam [0x417e89]
[cfdl004:32594] [ 8] /lib64/libc.so.6(__libc_start_main+0xf4) [0x2aaaade69994]
[cfdl004:32594] [ 9] pisoFoam(_ZN4Foam9UOPstream5writeEc+0xa1) [0x4162c9]
[cfdl004:32594] *** End of error message ***
[5] #8 __libc_start_main addr2line failed
[5] #9 Foam::UOPstream::write(char)
[cfdl004:32596] *** Process received signal ***
[cfdl004:32596] Signal: Floating point exception (8)
[cfdl004:32596] Signal code: (-6)
[cfdl004:32596] Failing at address: 0x7a8d00007f54
[cfdl004:32596] [ 0] /lib64/libc.so.6 [0x2aaaade7c2d0]
[cfdl004:32596] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x2aaaade7c265]
[cfdl004:32596] [ 2] /lib64/libc.so.6 [0x2aaaade7c2d0]
[cfdl004:32596] [ 3] /cm/shared/apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc43DPOpt/lib/libOpenFOAM.so(_ZN4Foam4sqrtERNS_5FieldIdEERKNS_5U ListIdEE+0x26) [0x2aaaad125be6]
[cfdl004:32596] [ 4] /cm/shared/apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc43DPOpt/lib/libincompressibleRASModels.so(_ZN4Foam4sqrtINS_12f vPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFi eldIdT_T0_EEEERKS7_+0x2ce) [0x2aaaab00cf4e]
[cfdl004:32596] [ 5] /cm/shared/apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc43DPOpt/lib/libincompressibleLESModels.so(_ZN4Foam14incompress ible9LESModels19DeardorffDiffStress7correctERKNS_3 tmpINS_14GeometricFieldINS_6TensorIdEENS_12fvPatch FieldENS_7volMeshEEEEE+0x829) [0x2aaaab4e6e39]
[cfdl004:32596] [ 6] /cm/shared/apps/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64Gcc43DPOpt/lib/libincompressibleLESModels.so(_ZN4Foam14incompress ible8LESModel7correctEv+0x35) [0x2aaaab436485]
[cfdl004:32596] [ 7] pisoFoam [0x417e89]
[cfdl004:32596] [ 8] /lib64/libc.so.6(__libc_start_main+0xf4) [0x2aaaade69994]
[cfdl004:32596] [ 9] pisoFoam(_ZN4Foam9UOPstream5writeEc+0xa1) [0x4162c9]
[cfdl004:32596] *** End of error message ***
I think the mistake is in my 0/B file because I'm not sure to set the values.
Here my B file:
FoamFile
version 2.0;
format ascii;
class volSymmTensorField;
object B;
dimensions [0 2 -2 0 0 0 0];
internalField uniform (0 0 0 0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (0 0 0 0 0 0);
interpolationScheme cell;
setAverage false;
average (0 0 0 0 0 0);
outlet
type inletOutlet;
inletValue uniform (0 0 0 0 0 0);
gitter
type zeroGradient;
aMantel
type inletOutlet;
eMantel
type slip;
Can somebody help me?
Regards,
Tom
Zuixy is offline   Reply With Quote
SimpleFoam case with SpalartAllmaras turbulence model implemented nedved OpenFOAM Running, Solving & CFD 2 November 30, 2014 23:43
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 10:02
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 14:57
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 11:26
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 17:15
