[LaunderGibsonRSTM-channel]
Old   November 8, 2011, 15:55
Default [LaunderGibsonRSTM-channel]
tonkiplis is on a distinguished road
Dear Foamers,
I'm trying to simulate a channel with the LaunderGibsonRSTM model. I would like to resolve the walls without using wall functions, my first y+ is therefore 0.63.
Unfortunately, my simulation blows up after a few time steps... I tried the solution provided by Sven in an other post regarding running the simulation with LaunderSharmaKE model and then use the RSTM... This is not working for me.
Relevant dictionaries of my 0 directory, fvSchemes, fvSolution are provided below.
initialisation epsilon:
|  \\    /   O peration     | Version:  1.6                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      epsilon;
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 4.5e-07;
boundaryField
    bottomWall
        //      type epsilonWallFunction;
        //      value   uniform 1e-8;
                type            fixedValue;
                value           uniform 1e-16;  //This is not 0!!!
    topWall
                type            fixedValue;
    sides1
        type            cyclic;
    sides2
        type            cyclic;
    inout1
        type            cyclic;
    inout2
        type            cyclic;
k:
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      k;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 6.75e-05;
boundaryField
    bottomWall
        type            fixedValue;                         //zeroGradient;
        value           uniform 1e-14;
    topWall
        type            fixedValue;
    sides1
        type            cyclic;//empty;
    sides2
    inout1
        type            cyclic;
    inout2
        type            cyclic;
R:
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
FoamFile
    version     2.0;
    format      ascii;
    class       volSymmTensorField;
    object      R;
internalField   uniform (0 0 0 0 0 0);
boundaryField
    bottomWall
      //        type            kqRWallFunction;
              type            fixedValue;
        value           uniform ( 0 0 0 0 0 0 );
    topWall
              type            fixedValue;
    sides1
    sides2
    inout1
        type            cyclic;
    inout2
        type            cyclic;
fvSchemes:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default              none;
    div(phi,U)           Gauss upwind;//Gauss limitedLinear 1.0;
    div(phi,k)           Gauss upwind;//Gauss limitedLinear 1;
    div(phi,epsilon)     Gauss upwind;//Gauss limitedLinear 1;
    div(phi,R)          Gauss upwind;//Gauss linear;
    div(R)              Gauss linear;
    div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nuEff,U) Gauss linear limited 0.333; //Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear limited 0.333; //Gauss upwind corrected;
    laplacian(DkEff,k) Gauss linear limited 0.333; //Gauss upwind corrected;
    laplacian(DepsilonEff,epsilon) Gauss linear limited 0.333; //Gauss upwind corrected;
    laplacian(DREff,R) Gauss linear limited 0.333; //Gauss upwind corrected;
    //laplacian(DnuTildaEff,nuTilda) Gauss linear limited 0.333; //Gauss upwind corrected;
    //laplacian(nuEff,U) Gauss linear corrected;
    // laplacian((1|A(U)),p) Gauss linear corrected;
    //laplacian(DkEff,k) Gauss linear corrected;
    //laplacian(DepsilonEff,epsilon) Gauss linear corrected;
    //laplacian(DREff,R) Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
 default         corrected;
fluxRequired
    default         no;
    p               ;
fvSolution:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-06;
        relTol          0.1;
    pFinal
       solver          PCG;
       preconditioner  DIC;
       tolerance       1e-09;
       relTol          0;
    U
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-07;
        relTol          0;
    R
        solver          PBiCG;
        tolerance       1e-07;
        relTol          0;
    epsilon
       solver          PBiCG;
       tolerance       1e-07;
       relTol          0;
PISO
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
//relaxationFactors
// p 0.2;
// U 0.7;
// k 0.5;
// epsilon 0.1;
// R 0.5;
  //  nuTilda 0.3;
tonkiplis is offline   Reply With Quote
Old   November 9, 2011, 09:04
issue solved. There exists no low Re formulation of the LaunderGibsonRSTM. Therefore wall functions have to be applied...
