variables missing from object registry
Old   October 31, 2011, 13:47
Default variables missing from object registry
Ganesh Vijayakumar
ganeshv is on a distinguished road
I've implemented a boundary condition very similar to the nuSgsWallFunction for LES. It works the first time when the turbulence object is created and the turbulence model calls the boundary condition at the end of updateSubGridScaleFields. However it doesn't work after the first time step when turbulence->correct() is called. Debugging tells me that 3 variables are missing from the object registry and they are U, U_0 and U_0_0. Is there anyway I'm messing up the object registry?
The whole code runs fine on my laptop with OpenFOAM-1.6-ext using gcc. However when I try to compile and run it on another system with OpenFOAM-1.6-ext (but using intel compilers though), it doesn't work. And that's the case I've reported here.
ganeshv is offline   Reply With Quote
Old   February 29, 2012, 08:12
Default same problem
Declan Carolan
declanj is on a distinguished road
I am having the same problem. Did you manage to find a workaround?
Dec
declanj is offline   Reply With Quote
boundary condition, object registry
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 15:56
using the object registry to access a particle cloud gregor OpenFOAM 1 June 8, 2011 06:58
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 05:55
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 16:49
