problem in gas-solid fluidized bed simulation |
October 29, 2011, 06:37 |
bhanwar singh
Rep Power: 15 |
Calculating averages
Courant Number mean: 0.605965 max: 1.27644 Max Ur Courant Number = 1.81825 Time = 0.061 DILUPBiCG: Solving for alpha, Initial residual = 0.274526, Final residual = 4.87573e-11, No Iterations 65 Dispersed phase volume fraction = 0.198 Min(alpha) = -0.0348437 Max(alpha) = 0.651658 DILUPBiCG: Solving for alpha, Initial residual = 0.0455936, Final residual = 3.07973e-11, No Iterations 37 Dispersed phase volume fraction = 0.198 Min(alpha) = -0.057928 Max(alpha) = 1.07894 #0 Foam::error:rintStack(Foam::Ostream&) in "/home/anoop/OpenFOAM/OpenFOAM-2.0.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/home/anoop/OpenFOAM/OpenFOAM-2.0.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/home/anoop/OpenFOAM/OpenFOAM-2.0.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #4 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/home/anoop/OpenFOAM/OpenFOAM-2.0.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/home/anoop/OpenFOAM/OpenFOAM-2.0.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/anoop/OpenFOAM/OpenFOAM-2.0.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/anoop/OpenFOAM/OpenFOAM-2.0.x/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #8 in "/home/anoop/OpenFOAM/OpenFOAM-2.0.x/platforms/linuxGccDPOpt/bin/twoPhaseEulerFoam" #9 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #10 in "/home/anoop/OpenFOAM/OpenFOAM-2.0.x/platforms/linuxGccDPOpt/bin/twoPhaseEulerFoam" im not getting how to solve this error. can anyone suggest me what is wrong here?? |
October 30, 2011, 03:39 |
Alberto Passalacqua
Rep Power: 36 |
You need to explain the case setup you are using if you want an answer.
P.S. The problem is here: Max(alpha) = 1.07894
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
about gas diameter in a fluidized bed | pan_zh | FLUENT | 0 | April 4, 2010 04:15 |
Top boundary condition for fluidized bed | stan | CFX | 0 | December 11, 2009 15:00 |
Problem with fluidized bed simulation using TwoPhaseEulerFoam | matthias_schreiber | OpenFOAM Running, Solving & CFD | 5 | June 12, 2008 06:49 |
Fluidized Bed Simulation | dyxu | OpenFOAM Running, Solving & CFD | 1 | August 4, 2007 21:50 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
