melting problem: looking for appropriate solvers
Like Tree186Likes
Old   June 12, 2012, 09:06
Smile isothermal phase change
  #21
Fabian Roesler
fabian_roesler is on a distinguished road
Hi
Sorry, I messed up the two solvers and thought that David needed my solver for OF_2.1.
I once compiled the meltFoam solver for isothermal phase change problems for OF_1.7. I remember the problem you are talking about. You can go for icoFoam but I would suggest using the buoyantBoussinesPimpleFoam. You can use pimpleControls instead simpleControls in the old solver. However syntax changed a little bit during the years.
Regards
Fabian
fabian_roesler is offline   Reply With Quote
Old   June 13, 2012, 05:06
Anja Miehe
AnjaMiehe is on a distinguished road
I have absolutely no idea which of the solvers David meant but know he has both and you additional ideas. Thanks for the like.
Regards, Anja
AnjaMiehe is offline   Reply With Quote
Old   August 15, 2012, 14:45
David
salehda is on a distinguished road
Thanks Fabian and Anja , this had been helpful to me and I agree , i think that buoyantboussinesqFoam is more suitable
salehda is offline   Reply With Quote
Old   November 7, 2012, 09:29
Chad
chaolian is on a distinguished road
Hello, AnjaI also modified meltFoam, instead of using enthalpy based update like yours I used temperature based update for my liquid fraction. All the others are similar to yours. But my results are not correct, do you have any suggestions? Thanks in advance.
chaolian is offline   Reply With Quote
Old   November 8, 2012, 04:09
Default linear step and continuous liquid fraction function
  #25
Fabian Roesler
Hi Chaolian
Nice that somebody else then Anja and I are interested into solid/liquid phase change problems. As you already know, the linear liquid fraction is the standard case from literature as proposed by many authors. There are some predictor corrector methods to update temperature to be consistent with the enthalpy-temperature-curve. This is necessary as the enthalpy equation is non-linear. In the case of a continuous liquid fraction function, you can substitute the function into the energy conservation equation. The drawback is that you still have a non-linear function. But as you do not solve for the liquid fraction anymore, the non-linear behavior is quite small. The error is small and so no or only a few iterations are necessary to solve the equation.
I once programed a solver for the linear function using the Brent et al. corrector method and some newer method by Voller. However the solver was not very stable and still 20 and more iterations for the temperature were necessary for solving.
Hope this helps
Best wishes
Fabian
atulAtcae and Kummi like this.
Old   November 8, 2012, 04:37
Chad
Originally Posted by fabian_roesler View Post
Hi Chaolian
Hope this helps
Best wishes
Fabian
Hello Fabian,
It's very nice to get your reply. I totally agree with you that your erf fitting approach, and some other predictor corrector method are better than classical linear approach. What I want to do is just try to implement the classical approach as a good practice to learn OpenFOAM structure and coding syntax, etc.
Many thanks for your reply and comments,
Best,
Chao
Old   February 8, 2013, 12:05
Tim Vincent
tvincent2k is on a distinguished road
Hi all
I posted that it might take some time to review the meltFoam solver and port it from OF_1.7 to OF_2.1 but I felt like doing it instantly. So here you go . I hope you enjoy it.
Regards
Fabian
This is great! I'm glad to see people have been working on this. I took this code and modified it to use the SIMPLE algorithm for steady-state conditions and was able to solve the gallium melting test case with it.
Now I'm wondering if you have made any progress on adding motion to the solid region. It seems like it is a little more complicated than simply adding a DC*(volVectorField solidVelocity) term to the explicit terms of the momentum equation. I tried that and the solution won't converge.
Any ideas?
tvincent2k is offline   Reply With Quote
Old   February 13, 2013, 08:09
Anja Miehe
Hello Tim,
nice to see that this thread does put together people interested in solving for solidification with OpenFOAM.
As far as your question is concerned, I do not know why your code does not converge. I started from the updated code I posted, everything is still transient although I am dealing with continuous casting and do have quasi steady-state conditions as well. Then I added in the "createFields.H" the following field:
    Info<< "Reading field Us\n" << endl;
    volVectorField Us
        IOobject
            "Us",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        mesh
And the velocity equation looks as follows:
    fvVectorMatrix UEqn
        fvm::ddt(U)
      + fvm::div(phi, U)
      - fvm::laplacian(nu, U)
      + fvm::Sp(DC, U) // since DC=>0, all time implicit is possible
      - DC*Us  // additional term for moving solidified shell << continuous casting >>
    UEqn.relax();
This works for me, although there may be "better" approaches.
The Us field, you first copy the U file, then you change for your velocities - if they are that easy to be got. I am dealing with a curvilinear geometry, so I do produce my Us velocity field using a Stokes solution, that means I do use simpleFoam with the exact same region and boundaries but very high viscosity. Then, I do copy the final velocity field to be my Us.
I hope that will help you.
Regards, Anja
Old   February 13, 2013, 11:45
Tim Vincent
Thanks Anja! It looks like that is basically the same thing that I was trying. I did a little more investigating and found that my problem was related to need for greater relaxation. I had my T relaxationFactor set to 0.5 but I needed it at 0.2 for my problem. I am guessing this is related to the interaction between the complex temperature/velocity boundary condition that I am using and the constant velocity of the solid region. Happily my solution is converging now.
Old   February 13, 2013, 12:52
Default close-contact melting
  #30
Fabian Roesler
Hi Anja,
hi Tim
I can just confirm your steps to include solid movement into the solver. I used the following:
fvVectorMatrix UEqn
      fvm::ddt(rho, U)
   + fvm::div(rhoPhi, U)
   - fvm::laplacian(mu, U)
   + rho*fvm::Sp(DC, U)
   - rho*DC*Us
The main question is whether you have a fixed and constant velocity like in continuous molding or if you have unconstrained melting with settling solid. In this case you will need some equations of movement to describe the settling process of the solid phase. This leads to a complex highly non-linear and coupled problem. However it is necessary to model close-contact melting. This is what I am doing at the moment. But the model and solver are not yet validated with experimental data.
Best wishes
Fabian
Old   March 4, 2013, 00:35
Chad
Hi all
Regards
Fabian
Thanks for your work. But why don't you have U solver in system/fvSolution file? Don't you solve UEqn?
Old   March 4, 2013, 03:24
Default momentumPredictor
  #32
Fabian Roesler
the U solver is only necessary when using a momentumPredictor step in PISO or PIMPLE. I don't do the predictor step as it does not help convergence for the melting case. Without predictor step, U is corrected after the pressure equation.
Regards
Fabian
Old   March 4, 2013, 13:07
Default Concentration equation
  #33
Yahoo is on a distinguished road
It is good to see people are working on melting problem. Have you guys ever tries to include species equation in your codes? That is what I am working on right now. Any comments?
Yahoo is offline   Reply With Quote
Old   March 4, 2013, 13:11
Chad
I know in thermodynamic model there are some species parameters specified in constant/thermophysicalProperties file. But I don't know too much of it. Here's something about this model: http://www.openfoam.org/docs/user/thermophysical.php
Old   March 5, 2013, 03:45
Default Species
  #35
Fabian Roesler
Hi there
No, never tried that. But it should not be that hard to implement it. Just add another volScalarField C and solve for it after the energy conservation equation. You also have to use another liquid fraction function and an additional one for the concentration. As all melting solvers here in the thread refer to the enthalpy porosity method by Voller and Prakash you could have a look for their solver. They wrote an article on the method for additional species transport.
Regards
Fabian
Yahoo likes this.
Old   March 5, 2013, 12:55
Fabian:
Thanks for your answer, I really appreciate it.
However, the problem I am working on is somehow different so I am not sure I can use your solver. In your paper you have updated liquid fraction by an error function (equation (6) in the paper), but I want to use Lever Micro-segregation rule for liquid fraction, and since it is numerical very unstable so I have implemented the liquid fraction updating scheme by C. Prakash and V. Voller. in "ON THE NUMERICAL SOLUTION OF CONTINUUM MIXTURE MODEL EQUATIONS DESCRIBING BINARY SOLID-LIQUID PHASE CHANG, Numerical Heat Transfer, Part B:Volume 15, Issue 2, 1989"
I will updated you guys in this thread if i find sth interesting.
Thamali and high_er like this.
Old   April 8, 2013, 19:30
Hi Fabian
Would you please let me know why you have used "mesh.solver( .select(finalIter))" in your code? What does this statement do?
Old   April 13, 2013, 03:47
Default p_rghEqn.solve(mesh.solver(p_rgh.select(pimple.fin alInnerIter())))
  #38
Fabian Roesler
Hi Yahoo
Have a look into pisoFoam solver. There you have this statement split up. In most solvers, you specify two different tolerances. One for the last iteration and the other for all previous iterations. An example:
    p_rghEqn.solve(mesh.solver(p_rgh.select(pimple.finalInnerIter())))
    p_rgh
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-8;
        relTol          0.01;
    p_rghFinal
        $p_rgh;
        relTol          0;
Here the relative tolerance is set to zero for the last inner iteration to be sure to reach the absolute tolerance of 1e-8. The statement just sais when to choose the final tolerance, namely for the finalInnerIter().
Regards
Fabian
Yahoo likes this.
Old   April 17, 2013, 14:35
Hi Guys
Have you tried to compile erfConvectiveMeltingPimpleFoam.C (Fabian's code for melting) on OpenFOAM 2.2.0? I am getting this compile error:
make: *** No rule to make target `/opt/OpenFOAM-2.2.0/src/finiteVolume/lnInclude/newFvPatchField.C', needed by `erfConvectiveMeltingPimpleFoam.dep'. Stop.
Old   April 18, 2013, 04:00
Default OF2.1 meltFoam
  #40
Fabian Roesler
you could just use the solver for OF2.1 I posted here :
http://www.cfd-online.com/Forums/ope...tml#post365835
Regards
Fabian
Yahoo likes this.
melting openfoam
Melting and solidification with free surface problem? cqlwj123 CFX 6 July 25, 2013 03:46
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 06:29
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Melting Problem M FLUENT 0 April 29, 2007 17:07
