melting problem: looking for appropriate solvers |
January 26, 2021, 01:09 |
Definition of lf
#321 | |
Rep Power: 5 |
January 26, 2021, 03:45 |
#322 | |
Rep Power: 5 |
Tutorial/functional case for solidificationMeltingSource you can test it from this paper https://www.researchgate.net/publica...th_experiments Regards, Mike |
January 28, 2021, 00:47 |
mesh dependent problem?
#323 | |
Rep Power: 5 |
August 18, 2021, 16:21 |
#324 | ||
James
Rep Power: 12 |
Hi Fabian, It has been some time but did you make your melting/solidification solver with free surface interface public? I had also developed a melt pool model for arc welding application including metal transfer. However I used the error function to calculate the liquid fraction. When I compare my simulation results with the melt pool data from the experiment, it gives good results in terms of predicting the depth of the fusion penetration but has significant discrepancy when comparing the the free surface length of the melt pool. I am starting to think if it is because my liquid fraction is not converging properly. Would it be possible to see your code specifically the part where liquid fraction and energy equation are iteratively solved. I did infact implemented the iteratively solving of liquid fraction and energy equation, thanks to the solver uploaded in this discussion. However, it always return the following error when running in parallel mode. It has never happened before. Would you have idea what could be the reason? Thanks ! Quote:
December 7, 2021, 03:57 |
droplet solidification
#325 |
SONG
Rep Power: 5 |
I am doing some work on droplet solidification. I tried to add TEqn into interFoam and the solver can be compiled, but temperature is very strange in the result of my test case. Did anyone find or build an appropriate solver? |
December 7, 2021, 04:02 |
#326 |
James
Rep Power: 12 |
Integrating TEqn to interFoam solver is well documented. You can find many documentation of it on the web. May be search with wolfdynamics team. In fact, the report presented in the link below also gives you a detail steps for implementaion. I suggest you try with first order scheme to run your test cases first.
http://www.tfd.chalmers.se/~hani/kur...inalReport.pdf |
December 7, 2021, 08:09 |
#327 | |
SONG
Rep Power: 5 |
Thank you very much! I will modify my solver according the report, and then run the case with first order scheme. |
July 20, 2022, 08:32 |
DC casting - Pull velocity
#328 |
Nikos
Rep Power: 14 |
Has anyone managed to apply a "pull velocity" for the solid in the meltingFoam solver? I am trying to simulate a direct chill (DC) casting process (https://www.substech.com/dokuwiki/do...ill_dc_casting) where the solidified metal is pulled out from the computational domain at a specified casting speed. Similar to what is implemented in Ansys Fluent (https://www.afs.enea.it/project/nept...th/node357.htm)
Any tips here? Best regards |
July 20, 2022, 08:47 |
#329 |
Nikos
Rep Power: 14 |
September 6, 2024, 12:43 |
Solidification with air phase on top
#330 |
JANGA RAKESH KUMAR
Rep Power: 2 |
Currently, I working on solidification and need to capture the shrinkage using VoF method. Is any one able to couple the solidification solver with interFoam solver ??
Or any one has the solver for this type of problem ?? Any help regarding this problem is greatly appreciated. Thanks in advance. Cheers Rakesh |
melting openfoam |
Melting and solidification with free surface problem? | cqlwj123 | CFX | 6 | July 25, 2013 02:46 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 05:29 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Melting Problem | M | FLUENT | 0 | April 29, 2007 16:07 |
