simpleFoam Floating point exception error -help
Old   August 17, 2011, 09:12
Default simpleFoam Floating point exception error -help
sudharsan
sudhasran is on a distinguished road
1. I generated the mesh in netgen and exported it to gmsh-version, Then used gmshTofoam to convert it to openFoam mesh.
2. Then i changed all the boundary conditions according to patchs in my boundary file from 'pitzDaily' tutorial folder
3. when i run simpleFoam i get the following, can anyone help with this ?
| \\ / O peration | Version: 1.7.0 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 1.7.0-113391ee57bd
Exec : simpleFoam
Date : Jul 17 2011
Time : 02:53:43
Host : caelinux
PID : 2683
Case : /media/sf_caelinux_shared/netgen_mesh/pitzDaily(copy)
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
// using new solver syntax:
p
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0.01;
U
solver PBiCG;
preconditioner DILU;
tolerance 1e-05;
relTol 0.1;
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model laminar
Starting time loop
Time = 1
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/opt/openfoam170/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
#3 void Foam::fvc::surfaceIntegrate<Foam::Vector<double> >(Foam::Field<Foam::Vector<double> >&, Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libfiniteVolume.so"
#4 Foam::tmp<Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libfiniteVolume.so"
#5 Foam::tmp<Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<Foam::Vector<double> >(Foam::tmp<Foam::GeometricField<Foam::Vector<doub le>, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libfiniteVolume.so"
#6 Foam::fv::gaussDivScheme<Foam::Tensor<double> >::fvcDiv(Foam::GeometricField<Foam::Tensor<double >, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libfiniteVolume.so"
#7 Foam::tmp<Foam::GeometricField<Foam::innerProduct< Foam::Vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<Foam::Tensor<double> >(Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libincompressibleRASModels.so"
#8 Foam::tmp<Foam::GeometricField<Foam::innerProduct< Foam::Vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<Foam::Tensor<double> >(Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam170/lib/linux64GccDPOpt/libincompressibleRASModels.so"
#9 Foam::incompressible::RASModels::laminar::divDevRe ff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const in "/opt/openfoam170/lib/linux64GccDPOpt/libincompressibleRASModels.so"
in "/opt/openfoam170/applications/bin/linux64GccDPOpt/simpleFoam"
#11 __libc_start_main in "/lib/libc.so.6"
#12
Floating point exception"
Thanks in advance
sudhasran is offline   Reply With Quote
Old   February 8, 2012, 02:32
Default Floating error
sheikh nasir is on a distinguished road
Hello.
I am getting floating error:invalid number. I am working on train moving in tunnel. Can any body help me. My email is sheikhnasir39@gmail.com
thanks
sheikh nasir is offline   Reply With Quote
Old   March 12, 2012, 12:41
Default same
Brendan
guitarbren is on a distinguished road
Hi, I get exactly the same error after running snappyhexmesh and then trying to run my solver (buoyantBoussineqSimpleFoam) if anyone has ideas on this I'd love to know!
guitarbren is offline   Reply With Quote
Old   March 12, 2012, 17:23
Brendan
I'm currently working on a 2D temperature driven flow and using a symmetry plane.
I've realised mine only crashes like this when I move the symmetry plane towards the geometry which was snapped to with snappyhexmesh. I'm not sure why it is doing this. Basically I need the symmetryplane or the edge of my domain to be closer to the geometry without it killing itself with this error...
MPI Error - simpleFoam - Floating Point Exception scott OpenFOAM Running, Solving & CFD 3 April 13, 2012 17:34
simpleFoam errors... timestep continuity error/Floating point exception headwing OpenFOAM 1 January 15, 2011 04:04
reactingFoam floating point exception pajofego OpenFOAM 0 November 6, 2010 18:29
Cannot Open .sim (Floating Point Exception) trex930 STAR-CCM+ 1 July 30, 2010 07:51
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
