August 16, 2011, 09:18 |
problem with cl coefficient
sandeep
Hi
i am trying to solve model of a slotted and split flap model and i used the wing dimensions same as for Boeing 737. i have sucefully meshed it. when i import in fluent and try to solve it i get the cl interms of 14000.00, i tried all possible ways. my input conditions are. velocity 100m/s at 4degrees angle of attack, viscous model is k-e model and the refeernce values are all given except enthalpy, depth and sepcific ratio. i can't understand the problem with it. i would like to hear some advice thank you |
pressure coefficient problem (FLUENT) | pimpin | FLUENT | 8 | March 24, 2014 23:37 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 06:59 |
Ammonia-liquid modelling. Problem with thermal expansion coefficient. | zhekka | FLUENT | 0 | February 9, 2010 16:06 |
Wall heat transfer coefficient (HTC) problem | Mohamed khamis | CFX | 1 | January 16, 2010 00:12 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
