twoPhaseEulerFoam running problem
Old   August 11, 2011, 10:17
Default twoPhaseEulerFoam running problem
Gitesh
Gitesh P is on a distinguished road
I am simulating gas-liquid flow with twoPhaseEulerFoam solver with OpenFOAM 1.7.
There following fields which I have initialized in case/0 directory,
- alpha (VF)
- k
- epsilon
- p(pressure)
- T(water-temperature)
- Ua(gas-velocity)
- Ub(water-velocity)
There is no any Theta field in case/0 but still I am getting following error.
PHP Code:
--> FOAM FATAL IO ERROR
cannot open file
file
: /home/patel/OpenFOAM/patel-1.7.1/run/STB31/0/Theta at line 0.
    From
function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 61.
FOAM exiting
Here is my fvSchemes file.
Please help me. I am new at OpenFOAM environment.
With regards,
Gitesh
File Type: gz fvSchemes.tar.gz (635 Bytes, 4 views)
Gitesh P is offline   Reply With Quote
Old   August 12, 2011, 05:26
pit
pit is on a distinguished road
Are you sure that you have the right files?
In the tutorial case the Theta file exist in 0/ and in the fvSolution/fvSchemes.
pit is offline   Reply With Quote
Old   August 12, 2011, 08:05
Gitesh
Now the problem is solved.
The field for theta has to be defined since the code reads it at the beginning of the simulation, when the object for the kinetic theory model is created.
In other words, for gas-liquid systems, the values you use in the kineticTheory dictionary play no role. You only have to make sure that boundary conditions are defined.
With regards,
Gitesh
Old   November 21, 2013, 00:46
tong is on a distinguished road
Hi Gitesh,
Would you be able to explain why kineticTheory dictionary plays no role for a gas-liquid simulation?
tong is offline   Reply With Quote
Problem About Running Fluent In Linux mitra FLUENT 18 June 20, 2019 03:11
Problem running buoyantFoam anke OpenFOAM 4 August 28, 2013 05:43
InterFoam / InterDyFoam running problem anon_c OpenFOAM Running, Solving & CFD 1 August 26, 2009 04:54
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
the problem of running star-cd after pro-star liu-jinsong Siemens 0 November 20, 2008 21:58
