Solver for transonic flow?
Like Tree11Likes
Old   February 22, 2012, 12:29
Abhinay Kulkarni is on a distinguished road
Hi Martin,
I am a beginer in openfoam as well as cfd. I wanted to somulate a stedy state compressible flow through a bent tube using the rhoSimpleFoam solver. My problem is the solver crashes after a few time time steps with the following error
Time = 186
smoothSolver: Solving for Ux, Initial residual = 0.00992166, Final residual = 0.000578669, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.00774996, Final residual = 0.000440937, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.0168676, Final residual = 0.000958473, No Iterations 4
DILUPBiCG: Solving for h, Initial residual = 0.0136817, Final residual = 8.63913e-05, No Iterations 2
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::calculate() in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libbasicThermophysicalModels.so"
#4 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::correct() in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libbasicThermophysicalModels.so"
in "/opt/openfoam201/platforms/linuxGccDPOpt/bin/rhoSimpleFoam"
#6 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Gleitkomma-Ausnahme
Could you kindly help me out with understanding this error??
I dont know why but i am not able to upload my case directories on the forum. If you want to have alook at them i can send them to you via email.
Would be great to get some help from you.
Regards
Abhinay
Abhinay Kulkarni is offline   Reply With Quote
Old   April 27, 2015, 12:02
Jimmy
MtnRunBeachBum is on a distinguished road
I see that I am 6 years late to this discussion, however, thought I would add my 2 cents, coming from the experimental (wind tunnel) side of the house.
To the best of my knowledge, still, few CFD codes can reproduce transonic results well. The aero is just funny, to put it simply, in this regime - particularly right around 1.0M (say 0.93-1.05 in general). That being said, I would believe CFD, including OF, has come a long way in covering this regime since 2009, particularly with the density-based solvers.
Just some food for thought. Does anyone know of reports showing correlation of OF results (with the more recent versions) against older OF code or even wind tunnel data?
MtnRunBeachBum is offline   Reply With Quote
Old   December 16, 2015, 05:59
Lewis
levvis is on a distinguished road
Hi all
I'm also new to OpenFOAM, and obviously late to this discussion.
But anyone visiting this thread late, may want to look at another, more recent thread.
http://www.cfd-online.com/Forums/ope...ntralfoam.html
These guys have progressed a solver that can deal with transonic flow, and supersonic. Yet to fully try it, but I will be.
levvis is offline   Reply With Quote
Solver for an incompressible, turbulent flow with heat transfer tH3f0rC3 OpenFOAM Running, Solving & CFD 9 June 17, 2019 07:12
How do I select solver options for external flow over an aircraft by fluent? hadieliasi FLUENT 5 May 2, 2011 04:54
pre-conditioning for low mach number compressible flow solver Shenren_CN Main CFD Forum 0 April 29, 2011 22:07
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
