July 14, 2011, 17:53 |
Turbulence boundary conditions
Ammar Tareen
Rep Power: 15 |
Hello World,
I created a half laval nozzle geometry and run air through it from one side to the other. Initially I ran a laminar simulation and found out that results tend to get quite turbulent. I'm now at the stage where I want to implement the k-epsilon model for turbulence. The trouble I'm having is that when I run the simulation I start to get nonsensical velocity, pressure and temperature profiles e.g. I start getting negative pressures and velocities as high has 10^24 m/s. This is because I don't understand the K-epsilon boundary conditions well enough. I am attaching my case file, can anybody give me any pointers as to how I should change the boundary conditions file to get reasonable results? The files P,T,U are ok, it's the rest of them that I don't understand. It's quite possible that I put the wrong bc's. I should point out that in the laminar case, I specify high pressure at the inlet and lower pressure at the velocity, and that's how flow develops. I am also attaching a picture of the results from the laminar simulation just so you know what the profiles look like. Any help would be greatly appreciated. Regards, Ammar. |
July 16, 2011, 04:43 |
k-epsilon bc settings
Namsu
Rep Power: 15 |
Hi
I am working on the impinging jets and also facing the same problem that I don’t really know how to set the k-epsilon boundary conditions, how to calculate the k, omega, epsilon, kqwallfunction, omegawallfunction, nutwallfuction. I appreciate if somebody gives a detailed answer so that a basic understanding would be developed. Regards. |
July 17, 2013, 09:02 |
Airfilter
Marcus
Rep Power: 13 |
i simulate with k-omega sst Modell, but this also interests me and that is why i've found some files for this. Here are the files compressed...maybe it helps you. For this topic, you must only write this in your browser to find the master thesis: www.tfd.chalmers.se/~hani/pdf.../AISwithOF.pdf I hope it helps... best regards Marcus |
Proper Pressure Boundary Conditions for Buoyant Flow | mchurchf | OpenFOAM | 0 | March 25, 2010 13:16 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 7, 2008 00:17 |
Fluent accuracy and boundary conditions | Paolo Lampitella | FLUENT | 0 | June 12, 2008 07:25 |
Help with boundary conditions | Dan | CFX | 0 | April 3, 2006 12:32 |
Boundary Conditions | Jan Ramboer | Main CFD Forum | 11 | August 16, 1999 09:59 |
