twoPhaseEulerFoam for flow inside a cyclonic separator |
July 10, 2011, 21:44 |
Rep Power: 17 |
Hi All,
I'm wondering if anyone has tried to simulate a flow inside a cyclonic separation using twoPhaseEulerFoam, example air + sand. I'm trying to simulate this problem base on ~/tutorial/multiphase/twoPhaseEulerFoam/bed solver, but the simulation become unstable after a few seconds. When I tried with one phase only (air) using pisoFoam, the simulation is OK without any problems, and I can see the swirling flow inside the cyclone. I suspect that, with the particle, the centrifugal force make the particle to move very fast and then somehow ... make the simulation unstable (I might be wrong on this). Does anyone have any different idea why I cannot simulate this cyclone geometry? I'm happy to send the mesh or other files from the three principle folders (~/0 ~/system ~/constant ) if anyone interested. Cheers
mali |
May 15, 2012, 08:33 |
HI Mali,
I am iterested in this topic. I would like to do the separator analysis. Do you already have a working case ? Or could you send me the mesh and settings ? Thanks Peter |
July 24, 2012, 10:12 |
#3 | |
ruma
Rep Power: 15 |
August 1, 2012, 17:05 |
Kuan-Lin Lee
Please send me the mesh file too.
I heard that, cyclone mesh is quite unstable...I might cause the problem. Anyway, I am working on this twophaseeulerFoam now, and i'm willing to discuss with you guys. jimmymiller38200@gmail.com |
May 9, 2013, 01:24 |
#5 | |
Shingo Kitakaze
Hi mali, Please send it to me if possible. shingo0323northwind@gmail.com Thanks. Shingo, |
January 23, 2014, 03:58 |
Rep Power: 14 |
September 25, 2014, 05:26 |
Tom
Rep Power: 12 |
Have you found out what was wrong with your settings? Please send me your files, I can try to figure out something. lukasz0004@gmail.com
Thanks you in advance. |
cyclone separator, twophaseeulerfoam |
Water-Air Separation inside cyclonic separator | soni_sandeep | FLUENT | 1 | August 14, 2010 11:12 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
Modelling the Heat flow inside the curing oven | Marios Vlad | CFX | 1 | February 6, 2008 08:11 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 13:37 |
