September 7, 2011, 09:27 |
#21 |
Thank you Alberto, I also found it and now trying to understand this expression.
Please see attached file Volumefield_reconstruction.pdf. I am looking for the original reference where this formulation is established. Could you please give some tips?
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at |
September 7, 2011, 22:16 |
#22 |
Alberto Passalacqua
Rep Power: 36 |
I do not have a reference for this, but I think you got it.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
September 8, 2011, 04:37 |
#23 |
Anton Kidess
Rep Power: 30 |
Alexander, I think it would be nice to have this on the wiki. If you agree, do you have the time to copy it to an article there?
September 8, 2011, 04:39 |
#24 |
Hi Anton!
Ok, I will put it there. And if Alberto doesn't mind, it would look better with his description of the body forces and the pressure gradient treatment technique.
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at Last edited by makaveli_lcf; September 8, 2011 at 04:43. Reason: Additions |
September 13, 2011, 02:20 |
#25 | |
Santiago Marquez Damian
Rep Power: 24 |
Alexander,
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
July 26, 2012, 05:28 |
Could you be so kind to write down the corresponding code for the equation for p?
#26 | |
Dear Alberto,
thank you very much for this very detailed explanation about the issue how to add correctly a body force to the (incompressible) momentum equation! I would be grateful if you would still specify the corresponding code for the p equation. Best regards, Vladimir Quote:
July 29, 2012, 16:20 |
#27 | ||||
Norbert Weber
Rep Power: 14 |
Hallo Vladimir,
I don't understand everything yet, but based on interFoam it should be sth like that: Quote:
Working on pisoFoam, I think rho has to be removed. I do not know if phi has to contain only the velocity flux, or the 'force flux', too. Any idea? For my understanding: Can someone give me a hint, what 'reconstruct' does? It 'adds' terms to the equation and changes A and H? But there must be a difference between Quote:
July 30, 2012, 02:33 |
plz help me
#28 |
vahid
Rep Power: 13 |
Hi Dear alberto again:
I want to add surface tension(sigma) in one solver,for this reason I added : please help me,and tell me ,How to correct this problem???#include ''fvCFD.H'' fvc::interpolate(interface.sigma()) in this code: Foam::tmp<Foam::volScalarField> Foam:haseChangeTwoPhaseMixtures::SchnerrSauer: Coeff ( const volScalarField& p ) const { volScalarField limitedAlpha1(min(max(alpha1_, scalar(0)), scalar(1))); volScalarField rho ( limitedAlpha1*rho1() + (scalar(1) - limitedAlpha1)*rho2() ); return //......I want to change it( <<sigma>> surface tension multiple in it): (3*rho1()*rho2())*sqrt(2/(3*rho1()))*(fvc::interpolate(interface.sigma())) *rRb(limitedAlpha1)/(rho*sqrt(mag(p - pSat()) + 0.01*pSat())); //.................................................. ...... } dont successful wmake, and seen(was not declared ): phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:113: error: 'interface' was not declared in this scope make: *** [Make/linux64GccDPOpt/SchnerrSauer.o] Error 1 |
June 4, 2014, 11:51 |
#29 |
M. Montero
Rep Power: 17 |
HI all,
How could it be done in case it is not a body force but a vectorField? All is in relation to the rotorDiskSource and how introducing this source in the momentum equation can create wiggles in the pressure field and velocity field. Thank you Last edited by be_inspired; June 6, 2014 at 08:14. |
February 23, 2015, 10:16 |
#30 | |
Peter
Rep Power: 14 |
Hello Harry, Did you finally solve your problem? I have met a similar problem regarding the body-force-weighted scheme for pressure interpolation. Do you have any ideas on this? Thanks a lot for your help and time! Best, Peter |
May 12, 2017, 10:26 |
#31 |
Roman G.
Rep Power: 9 |
I know this treat is old but I'm struggling with the implementation of the force term by the use of the Rhi-Chow interpolation. I'm using pimpleFoam. So far I added in the momentum predictor my force term like this: Code:
surfaceScalarField B_fs = fvc::interpolate(lorentz/rho) & mesh.Sf() if (pimple.momentumPredictor()) { solve ( UEqn == fvc::reconstruct ( - fvc::snGrad(p)* mesh.magSf() + B_fs ) ); fvOptions.correct(U); } I added a flux term in the phiHbyA equation: Code:
surfaceScalarField rAUf("rAUf", fvc::interpolate(rAU)); surfaceScalarField phil(rAUf*B_fs); surfaceScalarField phiHbyA ( "phiHbyA", fvc::flux(HbyA) + fvc::interpolate(rAU)*fvc::ddtCorr(U, phi) + phil ); Code:
U = HbyA + rAU*fvc::reconstruct((phil - pEqn.flux())/rAUf); Code:
Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 8.226416123979263e-05 Specified mass inflow : 0.0005613679754126387 Specified mass outflow : 6.154738583391114e-17 Adjustable mass outflow : 0 Thanks in advance |
May 18, 2017, 06:15 |
#32 |
Roman G.
Rep Power: 9 |
The problem is solved. I had to add the flux from the force after adjusting phi.
surfaceScalarField phil(rAUf*B_fs); surfaceScalarField phiHbyA ( "phiHbyA", fvc::flux(HbyA) + fvc::interpolate(rAU)*fvc::ddtCorr(U, phi) ); MRF.makeRelative(phiHbyA); adjustPhi(phiHbyA, U, p); phiHbyA += phil; |
September 19, 2017, 05:42 |
#33 | |
Przemek
Rep Power: 16 |
Have you also modified the line Code:
// Calculate the conservative fluxes phi = phiHbyA - p_rghEqn.flux();
best regards pblasiak |
September 21, 2017, 05:29 |
high residuals for p_rgh
#34 | |
Przemek
Rep Power: 16 |
I am trying to add body force to momentum equation like this where M is a body force. I based on buoyantBoussinesqPimpleFoam solver. I followed according to the instructions you provided and others on the forum and I changed the UEqn.H and pEqn.H as follows UEqn.H Code:
tmp<fvVectorMatrix> tUEqn ( fvm::ddt(U) + fvm::div(phi, U) + MRF.DDt(U) + turbulence->divDevReff(U) == fvOptions(U) ); fvVectorMatrix& UEqn = tUEqn.ref(); UEqn.relax(); fvOptions.constrain(UEqn); if (pimple.momentumPredictor()) { solve ( UEqn == fvc::reconstruct ( ( - ghf*fvc::snGrad(rhok) - fvc::snGrad(p_rgh) )*mesh.magSf() - (fvc::interpolate(M) & mesh.Sf()) ) ); fvOptions.correct(U); } Code:
{ volScalarField rAU("rAU", 1.0/UEqn.A()); surfaceScalarField rAUf("rAUf", fvc::interpolate(rAU)); volVectorField HbyA(constrainHbyA(rAU*UEqn.H(), U, p_rgh)); surfaceScalarField phig(-rAUf*ghf*fvc::snGrad(rhok)*mesh.magSf()); surfaceScalarField phiM(-rAUf*(fvc::interpolate(M) & mesh.Sf())); surfaceScalarField phiHbyA ( "phiHbyA", fvc::flux(HbyA) + rAUf*fvc::ddtCorr(U, phi) + phig + phiM ); MRF.makeRelative(phiHbyA); // Update the pressure BCs to ensure flux consistency constrainPressure(p_rgh, U, phiHbyA, rAUf, MRF); while (pimple.correctNonOrthogonal()) { fvScalarMatrix p_rghEqn ( fvm::laplacian(rAUf, p_rgh) == fvc::div(phiHbyA) ); p_rghEqn.setReference(pRefCell, getRefCellValue(p_rgh, pRefCell)); p_rghEqn.solve(mesh.solver(p_rgh.select(pimple.finalInnerIter()))); if (pimple.finalNonOrthogonalIter()) { // Calculate the conservative fluxes phi = phiHbyA - p_rghEqn.flux(); // Explicitly relax pressure for momentum corrector p_rgh.relax(); // Correct the momentum source with the pressure gradient flux // calculated from the relaxed pressure U = HbyA + rAU*fvc::reconstruct((phiM + phig - p_rghEqn.flux())/rAUf); //5 (+) U.correctBoundaryConditions(); fvOptions.correct(U); } } #include "continuityErrs.H" p = p_rgh + rhok*gh; if (p_rgh.needReference()) { p += dimensionedScalar ( "p", p.dimensions(), pRefValue - getRefCellValue(p, pRefCell) ); p_rgh = p - rhok*gh; } }
November 3, 2017, 05:34 |
#35 | |
Roman G.
Rep Power: 9 |
Hi gaza,
I had problems when adding a source term without adjusting the flux to ensure mass conservation. Try to add the source terms after adjusting phi to your flux phiHybA. Quote:
November 10, 2017, 07:35 |
#36 |
Przemek
Rep Power: 16 |
Hi Novel,
Thank you for your tip however in my case I do not see the difference after adjustPhi.
body force, force |
Help on 2D interpolation in StarCCM+ | madhuri | Siemens | 1 | May 30, 2017 04:20 |
urgent help needed (rhie-chow interpolation problem) | Ardalan | Main CFD Forum | 2 | March 18, 2011 16:22 |
Surface interpolation schemes and parallelization | jutta | OpenFOAM Running, Solving & CFD | 0 | February 25, 2010 15:32 |
momentum interpolation for collocated grid | Hadian | Main CFD Forum | 4 | December 25, 2009 08:25 |
spline interpolation | bajjal | Main CFD Forum | 0 | May 29, 2006 09:27 |
