A question about boundary condition??
Old   June 21, 2011, 22:13
Default A question about boundary condition??
lfgmarc's Avatar
Luis Felipe Gutierrez Marcantoni
lfgmarc is on a distinguished road
Send a message via MSN to lfgmarc
Hi, I trying to setup a case, in which I need that the inlet pressure changing according to the value of the outlet pressure. any suggestion ?
Best Regards, and thanks for your help
fg
Felipe G
lfgmarc is offline   Reply With Quote
Old   June 22, 2011, 18:08
Walter Schostak
wschosta is on a distinguished road
one possible solution is as follows:
if your inlet condition needs to be the same as your outlet you could make the walls at your inlet and outlet cyclic (periodic) which would basically mean that anything going out the outlet would come back in through the inlet. The problem with that is it also preserves any funky things going on with your fluid. And because the pressure is changing I'm guessing some funky things are happening.
that said I've tried my own interesting wall conditions and you might want to look at swak4foam, it was recommended to me while I was on my quest. It's an additional library that allows you to use equations for the boundary conditions. I didn't end up using it so I don't really know much more about it besides that.
best of luck!
Walter
wschosta is offline   Reply With Quote
velocity profile inlet boundary condition question Lcw FLUENT 3 August 3, 2012 06:53
question about OpenFoam-temperatureGradient boundary condition gulru OpenFOAM 2 March 24, 2011 12:50
a simple Boundary condition question prapanj OpenFOAM Running, Solving & CFD 1 March 16, 2009 08:51
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
The Boundary Condition about the Flat Plate boing Main CFD Forum 1 January 6, 2002 17:53
