Foam::error::PrintStack
Like Tree81Likes
Old   August 7, 2018, 12:18
Smile
  #81
gouravjee is on a distinguished road
Originally Posted by Lighto View Post
Hi everyone,
I have a similar problem in OpenFOAM while running a modified pimplefoam with lagrangian particle tracking. The solver is working in PISO mode, and after a few time steps it stops with FPE error.
I have time-varying boundary conditions (I specified them with a txt file) for velocity at the inlet and noSlip conditions at walls and zeroGradient at outlet, while for the pressure I imposed a zeroGradient conditions in all the patches and uniform 0 at the outlet.
I am also running in parallel on a machine with 16 cores.
The error log is the following:
Foam::error::printStack(Foam::Ostream&) at ??:?
[13] #1  Foam::sigFpe::sigHandler(int) at ??:?
[13] #2  ? at sigaction.c:?m
[13] #3  Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, long) at ??:?
[13] #4  Foam::symGaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, long) const at ??:?
[13] #5  Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[13] #6  Foam::fvMatrix<Foam::Vector<double> >::solveSegregated(Foam::dictionary const&) at ??:?
[13] #7  Foam::fvMatrix<Foam::Vector<double> >::solve(Foam::dictionary const&) at ??:?
[13] #8  ? at ??:?
[13] #9  ? at ??:?
[13] #10  __libc_start_main at ??:?
[13] #11  ? at ??:?
[nodo-b06:21640] *** Process received signal ***
[nodo-b06:21640] Signal: Floating point exception (8)
[nodo-b06:21640] Signal code:  (-6)
I think that the problem is the courant number, that at a certain time goes above 1... I have already refined the time step and the problem just shifted from 0.036 to 0.040 (of the "real" time of the phenomenon that I have to simulate). It took me a week of simulation, so I can't refine that much...
I attach here two file showing the Co values with respect to the inlet velocity values.
Thanks for helping me
gouravjee is offline   Reply With Quote
Old   August 7, 2018, 12:21
Hi everyone,
[13] #8  ? at ??:?
[13] #9  ? at ??:?
[13] #11  ? at ??:?
Refer to this link for identifying error:
https://en.wikipedia.org/wiki/Signal_(IPC)#SIGFPE
Old   September 2, 2018, 13:03
Default Foam::error::PrintStack
  #83
ceren's Avatar
ceren cilavdaroğlu
ceren is on a distinguished road
Hello all,
I am having a similar error in using weirOwerflow
Below is the log folder:
Courant Number mean: 5.66695e+09 max: 3.11881e+15
Interface Courant Number mean: 0.0013693 max: 334.573
deltaT = 3.76816e-51
Time = 0.615178
PIMPLE: iteration 1
MULES: Solving for alpha.water
Phase-1 volume fraction = 1  Min(alpha.water) = 0.656874  Max(alpha.water) = 1.29113
Phase-1 volume fraction = 1  Min(alpha.water) = 0.656874  Max(alpha.water) = 1.36343
DICPCG:  Solving for p_rgh, Initial residual = 0.991688, Final residual = 0.0386321, No Iterations 2
time step continuity errors : sum local = 3.17812e+17, global = 1.31038e+17, cumulative = 1.31038e+17
DICPCG:  Solving for p_rgh, Initial residual = 9.85132e-44, Final residual = 9.85132e-44, No Iterations 0
time step continuity errors : sum local = 3.17915e+17, global = 1.31083e+17, cumulative = 2.62121e+17
DICPCG:  Solving for p_rgh, Initial residual = 9.8524e-44, Final residual = 9.8524e-44, No Iterations 0
time step continuity errors : sum local = 3.1795e+17, global = 1.31132e+17, cumulative = 3.93252e+17
mpirun noticed that process rank 0 with PID 10107 on node ceren-CASPER-BILGISAYAR-SISTEMLERI-A-S exited on signal 8 (Floating point exception).
i am the beginner. please help me..
Thanks in advance for your reply
Ceren
ceren is offline   Reply With Quote
Old   September 7, 2018, 12:16
Deep
deepbandivadekar is on a distinguished road
Originally Posted by ceren View Post
Hello all,
Time = 0.615178
PIMPLE: iteration 1
Ceren
Your Courant Numbers (entries in bold) and timestep continuity errors are huge. This suggests:
  1. Your time step for the cell sizes are not compatible. Try reducing the timestep.
  2. There's something that's causing imbalance in the system and increasing the continuity error. Take hard look at the boundary conditions again. See if all patches are correctly defined.
deepbandivadekar is offline   Reply With Quote
Old   September 18, 2019, 07:53
Default buoyantSimpleFoam crash - turbulence related
  #85
Gareth
bullmut is on a distinguished road
Hi All
this is a great thread, old though it may be, and very informative.
I will start with my problem. I am trying to run buoyantSimpleFoam on a engine test cell. I am not modelling flow in the engine. Instead I have no mesh where the engine sis. Instead i have inlet and outlet boundaries for the engine inlet and outlet. I am trying to see re-circulation within the test cell (room).
I started out the simulation with just simpleFoam, to see if a cold flow run would work,. yeah success.
Then i added turbulence to the mix and also success.
The final step was adding heat, so i switched to buoyantSimplefoma as the temperature difference between the room and engine exhaust was greater than 10 degrees. Below you can see the last section of my log file. I am getting a floating point exception. So there are some odd maths going on.
Time = 5
DILUPBiCGStab:  Solving for Ux, Initial residual = 0.181033, Final residual = 3.19602e-05, No Iterations 1
DILUPBiCGStab:  Solving for Uy, Initial residual = 0.236924, Final residual = 6.02134e-05, No Iterations 1
DILUPBiCGStab:  Solving for Uz, Initial residual = 0.210526, Final residual = 3.29874e-05, No Iterations 1
DILUPBiCGStab:  Solving for h, Initial residual = 0.0253854, Final residual = 6.01331e-05, No Iterations 2
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#8  Foam::fvMatrix<double>::solve() at ??:?
#9  ? at ??:?
#10  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11  ? at ??:?
Floating point exception (core dumped)
My first stop was checkMesh which said i had a good mesh (created with snappy).
After reading through this thread i followed the crumbs and saw my epsilon was going negative. And this knocked on to how my p_rgh was being calculated. So i now assume i have the wrong boundary condition epsilon and k. I have attached the patch summary and the log file of the simulation run. If anyone could please advise on what i am supposed to use for boundary conditions i would be very grateful.
For reference my patches are named:
Box_Wall, Box_rig - walls
Box_inlet - air inlet from atmosphere
Box_outlet - air outlet, suction based with volume flow rate
Box_port - inlet/outlet not sure - exposed to atmosphere
Box_t_in - engine inlet, modeled as suction outlet
box_t_out - engine outlet,
Box_exhaust - outlet exposed to atmosphere,
Look fwd to your help
bullmut is offline   Reply With Quote
Old   September 27, 2019, 15:11
ASurendran is on a distinguished road
Hi Gareth,
I am also experiencing a similar error when I try to run buoyantSimpleFoam. I am very new to OpenFOAM. My problem is that of a heat exchanger (cold cylinder) in hot flow. For the moment, I am only looking at a 2D problem. In order to familiarise myself with OpenFOAM, I first tried to work on the cold flow case using simpleFoam and it works fine. The moment I add heat transfer, it goes bonkers and I am not able to understand the error.
From what Bruno mentioned in the beginning of the thread, all I could gather was that somewhere in my code there is some nasty math happening. But I am not able to figure out where. I am also not very confident with my BCs. I thought flow over a cylinder with heat transfer is sort of a standard problem that many people must have worked on. Unfortunately, the countless hours spend on the internet trying to figure out the BCs didn't help me much. Eventually, I decided to follow the example of CicuitBoardCooling in the tutorials. But, still going nowhere.
If somebody wants to see how my domain looks like, it is nothing but a half cylinder with symmetry conditions on the top and bottom wall. There is a velocity inlet and the pressure is assumed to be constant. The flow is hot and the tube is cold with a fixed temperature prescribed to it. I would have included the schematic if I knew how to include as attachments. Hope somebody can help me with that as well.
If somebody is willing to have a look at my codes, do let me know, I can post them here.
Cheers!
ASurendran is offline   Reply With Quote
Old   September 27, 2019, 15:29
Rsingh
iamranjitsingh is on a distinguished road
Originally Posted by ASurendran View Post
Hi Gareth,
Cheers!
Dear ASurendran, Just check out the boundary conditions for pressure and velocity you have given. The solver you had mentioned here is default available in OpenFOAM, so there is no doubt regarding accuracy. the only thing here can be modified is pressure velocity, and temperature BC. Therefore have a look on in-built bouyantSimpleFOAM tutorial.
iamranjitsingh is offline   Reply With Quote
Old   September 27, 2019, 15:44
Hi Ranjit,
Thank you for the reply. The closest tutorial that I can compare with my case is that of CircuitCooling. Shown below are my P, T and U codes. I am really doubtful of how to define p_rgh though, as this concept is a bit tricky for me to grasp. Is p_rgh really pressure? what value should we give? etc.
Code for P:
| \\ / O peration | Version: 2.3.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [1 -1 -2 0 0 0 0]; // P
//dimensions [0 2 -2 0 0 0 0]; // P/rho
internalField uniform 1e5;//
boundaryField
inlet
type zeroGradient;
//value uniform 1e5;
outlet
type fixedValue; //
value uniform 1e5;// $internalField; //
top
type symmetry;
bottom
type symmetry;
cylinder
type zeroGradient;
defaultFaces
type empty;
Code for T:
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 1500;
boundaryField
top
type symmetry;
bottom
type symmetry;
inlet
type fixedValue;
value uniform 1500;
outlet
//type zeroGradient;
type inletOutlet;
inletValue uniform 1500;
value uniform 1500;
cylinder
type fixedValue;
value uniform 300;
defaultFaces
type empty;
Code for U:
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (21.0 0 0); // 0.627
boundaryField
inlet
type fixedValue;
value uniform (21.0 0 0);
outlet
type inletOutlet;
inletValue uniform (0 0 0);
top
type symmetry;
bottom
type symmetry;
cylinder
type noSlip;
//type fixedValue;
//value uniform (0 0 0);
defaultFaces
type empty;
And finally Code for p_rgh:
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
object p_rgh;
boundaryField
inlet
type zeroGradient;
//type fixedFluxPressure;
//gradient uniform 0;
outlet
type fixedValue;
value uniform 1e5;
top
type symmetry;
bottom
type symmetry;
cylinder
type zeroGradient;
defaultFaces
type empty;
My simulation crashes after the 9th step. Don't know why.
Old   September 30, 2019, 04:57
Gareth
Hi ASurendran
In my case there were some poor cells causing me trouble. while checkMesh gave me the all clear, a personal inspection of the mesh showed me what to fix.
But i think the boundary conditions are usually a culprit. If you want to eliminate meshing as a possible source try a very simple setup with well defines cells...
regards
Old   September 30, 2019, 05:55
Hi Gareth,
Thank you for your suggestion. I will check the mesh and BCs as suggested.
Kind regards
Old   October 3, 2019, 08:01
Hi All,
I forgot to mention that I work on High pressure flows with high temperature differences i.e., my domain pressure is of the order of 10bars and the difference in temperature between the flow and the heat exchanger is around 1100K. Has anyone encountered such situations?
To Gareth - I tried other possible BCs. Sadly, none of them worked.
Old   December 21, 2022, 05:50
Default Hello I'm having same issue
  #92
Paul
Paulzamb is on a distinguished road
My case is a floating sphere by the influence of the waves, with a morphing mesh
Courant Number mean: 0.000235953687854 max: 43.0429793229
Interface Courant Number mean: 4.53166165807e-05 max: 42.9775097418
Time = 0.003
time step continuity errors : sum local = 3994.71241642, global = 6.63671275067e-12, cumulative = 3.23341262596e-08
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#2 ? in /lib/x86_64-linux-gnu/libpthread.so.0
#3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
#4 Foam::symGaussSeidelSmoother::scalarSmooth(Foam::F ield<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
#5 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
#6 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#7 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#8 Foam::fvMatrix<double>::solveSegregatedOrCoupled(F oam::dictionary const&) at ??:?
#9 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:?
#10 Foam::fvMatrix<double>::solve() in /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/interFoam
#11 ? in /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/interFoam
#12 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#13 ? in /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/interFoam
Paulzamb is offline   Reply With Quote
Old   May 21, 2024, 08:56
Goind Sharma
govind_IITD is on a distinguished road
HI,
I am having the same type of issue (parallel mode), but it works fine in serial mode.
solving3-D cloud reactingCloud1
[4] #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
[4] #1 Foam::sigFpe::sigHandler(int) at ??:?
[4] #2 ? in /lib/x86_64-linux-gnu/libc.so.6
[4] #3 ? in /lib/x86_64-linux-gnu/libm.so.6
[4] #4 exp in /lib/x86_64-linux-gnu/libm.so.6
[4] #5 Foam::integrationSchemes::analytical::dtEff(double , double) const at ??:?
[4] #6 ? in ~/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/bin/reactingParcelFoam
[4] #7 ? in ~/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/bin/reactingParcelFoam
[4] #8 ? in ~/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/bin/reactingParcelFoam
[4] #9 ? in ~/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/bin/reactingParcelFoam
[4] #10 ? in ~/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/bin/reactingParcelFoam
[4] #11 ? in ~/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/bin/reactingParcelFoam
[4] #12 ? in ~/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/bin/reactingParcelFoam
[4] #13 ? in ~/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/bin/reactingParcelFoam
[4] #14 ? in /lib/x86_64-linux-gnu/libc.so.6
[4] #15 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
[4] #16 ? in ~/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/bin/reactingParcelFoam
[ufifilters-HP-Z4-G4-Workstation:1219358] *** Process received signal ***
[ufifilters-HP-Z4-G4-Workstation:1219358] Signal: Floating point exception (8)
[ufifilters-HP-Z4-G4-Workstation:1219358] Signal code: (-6)
[ufifilters-HP-Z4-G4-Workstation:1219358] Failing at address: 0x3e800129b1e
[ufifilters-HP-Z4-G4-Workstation:1219358] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7661fc442520]
[ufifilters-HP-Z4-G4-Workstation:1219358] [ 1] /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7661fc4969fc]
[ufifilters-HP-Z4-G4-Workstation:1219358] [ 2] /lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7661fc442476]
[ufifilters-HP-Z4-G4-Workstation:1219358] [ 3] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7661fc442520]
[ufifilters-HP-Z4-G4-Workstation:1219358] [ 4] /lib/x86_64-linux-gnu/libm.so.6(+0x709e0)[0x766200f899e0]
[ufifilters-HP-Z4-G4-Workstation:1219358] [ 5] /lib/x86_64-linux-gnu/libm.so.6(exp+0x13)[0x766200f50f03]
[ufifilters-HP-Z4-G4-Workstation:1219358] [ 6] /home/ufi-filters/OpenFOAM-v2112/platforms/linux64GccDPInt32Opt/lib/liblagrangianIntermediate.so(_ZNK4Foam18integratio nSchemes10analytical5dtEffEdd+0x43)[0x7661ff59a573]
[ufifilters-HP-Z4-G4-Workstation:1219358] [ 7] reactingParcelFoam(+0xc23c2)[0x63d71695c3c2]
[ufifilters-HP-Z4-G4-Workstation:1219358] [ 8] reactingParcelFoam(+0xe1156)[0x63d71697b156]
[ufifilters-HP-Z4-G4-Workstation:1219358] [ 9] reactingParcelFoam(+0xec917)[0x63d716986917]
[ufifilters-HP-Z4-G4-Workstation:1219358] [10] reactingParcelFoam(+0xed613)[0x63d716987613]
[ufifilters-HP-Z4-G4-Workstation:1219358] [11] reactingParcelFoam(+0x15925d)[0x63d7169f325d]
[ufifilters-HP-Z4-G4-Workstation:1219358] [12] reactingParcelFoam(+0x159c09)[0x63d7169f3c09]
[ufifilters-HP-Z4-G4-Workstation:1219358] [13] reactingParcelFoam(+0x159e6c)[0x63d7169f3e6c]
[ufifilters-HP-Z4-G4-Workstation:1219358] [14] reactingParcelFoam(+0x5be4c)[0x63d7168f5e4c]
[ufifilters-HP-Z4-G4-Workstation:1219358] [15] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7661fc429d90]
[ufifilters-HP-Z4-G4-Workstation:1219358] [16] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7661fc429e40]
[ufifilters-HP-Z4-G4-Workstation:1219358] [17] reactingParcelFoam(+0x62ad5)[0x63d7168fcad5]
[ufifilters-HP-Z4-G4-Workstation:1219358] *** End of error message ***
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 4 with PID 0 on node ufifilters-HP-Z4-G4-Workstation exited on signal 8 (Floating point exception).
And one more thing, I tried to compile the openfoam in debug mod but it failed, couldn't compile.
How do I look up at this problem?
Regards,
Govind
govind_IITD is offline   Reply With Quote
FoamerrorprintStack mayank OpenFOAM Running, Solving & CFD 38 November 25, 2011 23:58
