Orifice Plate with a fully developed flow - Problems with convergence
Old   June 3, 2011, 19:50
Default Orifice Plate with a fully developed flow - Problems with convergence
Jonathas Assunção de Castro
jonmec is on a distinguished road
Hy .... i'm trying to simulate the pressure drop caused by the obstruction in a orifice plate. So i generated a duct upstream the obstruction with the purpose of obtaining a fully developed flow before the hole.
However simpleFoam doesn't converge. Please, help me. My term is ending and I still did not achieve satisfactory results.
My turbulence model is kepsilon. CheckMesh is OK. My Re is 10000.
Here my fvSchemes
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss upwind;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div(phi,R)      Gauss upwind;
    div(R)          Gauss linear;
    div(phi,nuTilda) Gauss upwind;
    div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nuEff,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DepsilonEff,epsilon) Gauss linear corrected;
    laplacian(DREff,R) Gauss linear corrected;
    laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p;
Now my fvSolution
solvers
    p PCG
        preconditioner   DIC;
        tolerance        1e-06;
        relTol           0.01;
    U PBiCG
        preconditioner   DILU;
        tolerance        1e-05;
        relTol           0.1;
    k PBiCG
        tolerance        1e-05;
        relTol           0.1;
    epsilon PBiCG
        tolerance        1e-05;
        relTol           0.1;
    R PBiCG
        tolerance        1e-05;
        relTol           0.1;
    nuTilda PBiCG
        tolerance        1e-05;
        relTol           0.1;
SIMPLE
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
relaxationFactors
    p               0.3;
    U               0.75;
    k               0.7;
    epsilon         0.7;
    R               0.7;
    nuTilda         0.7;
Time 0 for U
 inlet
        type            fixedValue;
        value           uniform (0 0 3);
    wall
        type            fixedValue;
        value           uniform (0 0 0);
   simetria
        type            symmetryPlane;
    outlet
        type            zeroGradient;
Time 0 for p
  inlet
        type            zeroGradient;
    wall
        type            zeroGradient;
   simetria
        type            symmetryPlane;
    outlet
        type            fixedValue;
        value           uniform 0;
My log file
Time = 456
DILUPBiCG:  Solving for Ux, Initial residual = 0.000512103, Final residual = 1.48703e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000401474, Final residual = 1.10876e-05, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 4.50922e-05, Final residual = 1.18828e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.00228803, Final residual = 2.27407e-05, No Iterations 164
time step continuity errors : sum local = 0.00238667, global = -6.0628e-05, cumulative = -0.127041
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000388629, Final residual = 4.27324e-06, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00396427, Final residual = 3.75563e-05, No Iterations 2
ExecutionTime = 7063.29 s  ClockTime = 7079 s
Time = 457
DILUPBiCG:  Solving for Ux, Initial residual = 0.00050372, Final residual = 1.48732e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000393417, Final residual = 1.0608e-05, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 5.00215e-05, Final residual = 1.27123e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.00226589, Final residual = 2.24865e-05, No Iterations 163
time step continuity errors : sum local = 0.00235924, global = -0.000164009, cumulative = -0.127205
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000388612, Final residual = 4.25304e-06, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00397533, Final residual = 3.7655e-05, No Iterations 2
ExecutionTime = 7073.22 s  ClockTime = 7089 s
Time = 458
DILUPBiCG:  Solving for Ux, Initial residual = 0.000504411, Final residual = 1.47415e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000394789, Final residual = 1.04873e-05, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 6.91581e-05, Final residual = 1.54967e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.00224121, Final residual = 2.08246e-05, No Iterations 755
time step continuity errors : sum local = 0.00218417, global = 2.1535e-06, cumulative = -0.127203
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000388532, Final residual = 4.2453e-06, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00398655, Final residual = 3.77526e-05, No Iterations 2
ExecutionTime = 7102.86 s  ClockTime = 7119 s
Time = 459
DILUPBiCG:  Solving for Ux, Initial residual = 0.000517339, Final residual = 1.54808e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000410883, Final residual = 1.0981e-05, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 6.09888e-05, Final residual = 1.6352e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.00229398, Final residual = 2.18083e-05, No Iterations 179
time step continuity errors : sum local = 0.00229149, global = -5.6239e-05, cumulative = -0.127259
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000389129, Final residual = 4.23547e-06, No Iterations 2
bounding epsilon, min: -0.178234 max: 364036 average: 10221.9
DILUPBiCG:  Solving for k, Initial residual = 0.00399978, Final residual = 3.78724e-05, No Iterations 2
ExecutionTime = 7113.5 s  ClockTime = 7130 s
Time = 460
DILUPBiCG:  Solving for Ux, Initial residual = 0.000483808, Final residual = 1.44835e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000380046, Final residual = 1.13412e-05, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 4.13029e-05, Final residual = 1.19397e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.00227407, Final residual = 2.21498e-05, No Iterations 89
time step continuity errors : sum local = 0.00232672, global = 5.68528e-05, cumulative = -0.127202
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000389398, Final residual = 4.23249e-06, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00401211, Final residual = 3.79844e-05, No Iterations 2
ExecutionTime = 7120.94 s  ClockTime = 7137 s
Time = 461
DILUPBiCG:  Solving for Ux, Initial residual = 0.00048556, Final residual = 1.45664e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000381206, Final residual = 1.11524e-05, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 4.07961e-05, Final residual = 1.169e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.00225496, Final residual = 2.21822e-05, No Iterations 245
time step continuity errors : sum local = 0.00232942, global = 6.41572e-06, cumulative = -0.127196
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000389578, Final residual = 4.22086e-06, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00402382, Final residual = 3.80896e-05, No Iterations 2
ExecutionTime = 7133.82 s  ClockTime = 7150 s
Time = 462
DILUPBiCG:  Solving for Ux, Initial residual = 0.000498512, Final residual = 1.45726e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000391302, Final residual = 1.0683e-05, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 5.1133e-05, Final residual = 1.2756e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.00224598, Final residual = 2.19644e-05, No Iterations 332
time step continuity errors : sum local = 0.00230557, global = -4.69691e-05, cumulative = -0.127242
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000389523, Final residual = 4.20593e-06, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00403516, Final residual = 3.81893e-05, No Iterations 2
ExecutionTime = 7149.37 s  ClockTime = 7165 s
Time = 463
DILUPBiCG:  Solving for Ux, Initial residual = 0.000508548, Final residual = 1.4678e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000398041, Final residual = 1.05333e-05, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 6.0973e-05, Final residual = 1.43804e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.00222826, Final residual = 2.12836e-05, No Iterations 99
time step continuity errors : sum local = 0.00223302, global = -0.000169687, cumulative = -0.127412
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000389354, Final residual = 4.18671e-06, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00404604, Final residual = 3.82852e-05, No Iterations 2
ExecutionTime = 7157.2 s  ClockTime = 7173 s
Time = 464
DILUPBiCG:  Solving for Ux, Initial residual = 0.000509481, Final residual = 1.44912e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000397803, Final residual = 1.04437e-05, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 7.94906e-05, Final residual = 1.70902e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.0022065, Final residual = 2.19899e-05, No Iterations 622
time step continuity errors : sum local = 0.0023064, global = 6.12007e-06, cumulative = -0.127406
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000389208, Final residual = 4.17798e-06, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00405747, Final residual = 3.8384e-05, No Iterations 2
ExecutionTime = 7182.9 s  ClockTime = 7199 s
Time = 492
DILUPBiCG:  Solving for Ux, Initial residual = 0.000463906, Final residual = 1.2439e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000364687, Final residual = 9.88269e-06, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 4.63961e-05, Final residual = 1.13945e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.00209672, Final residual = 2.01067e-05, No Iterations 753
time step continuity errors : sum local = 0.00211535, global = -1.14803e-06, cumulative = -0.127467
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000393129, Final residual = 3.98323e-06, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00440507, Final residual = 4.15127e-05, No Iterations 2
ExecutionTime = 7625.11 s  ClockTime = 7642 s
Time = 493
DILUPBiCG:  Solving for Ux, Initial residual = 0.000485382, Final residual = 1.26639e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000382994, Final residual = 2.55656e-05, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 7.7196e-05, Final residual = 1.9067e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.00216746, Final residual = 2.16433e-05, No Iterations 24
time step continuity errors : sum local = 0.00228078, global = 5.59411e-05, cumulative = -0.127411
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000393817, Final residual = 3.99394e-06, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00442006, Final residual = 4.1653e-05, No Iterations 2
ExecutionTime = 7630.39 s  ClockTime = 7647 s
Time = 494
DILUPBiCG:  Solving for Ux, Initial residual = 0.000454229, Final residual = 1.35997e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000355828, Final residual = 1.68204e-05, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 4.73086e-05, Final residual = 1.32974e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.00214212, Final residual = 2.09423e-05, No Iterations 131
time step continuity errors : sum local = 0.00220641, global = 0.000105288, cumulative = -0.127306
DILUPBiCG:  Solving for epsilon, Initial residual = 0.00039425, Final residual = 3.9975e-06, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00443389, Final residual = 4.17823e-05, No Iterations 2
ExecutionTime = 7638.92 s  ClockTime = 7656 s
Time = 495
DILUPBiCG:  Solving for Ux, Initial residual = 0.000453295, Final residual = 1.3394e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000356429, Final residual = 9.5217e-06, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 3.69828e-05, Final residual = 1.10254e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.00212543, Final residual = 2.08334e-05, No Iterations 340
time step continuity errors : sum local = 0.00219434, global = 8.02239e-05, cumulative = -0.127226
DILUPBiCG:  Solving for epsilon, Initial residual = 0.00039448, Final residual = 3.99306e-06, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00444701, Final residual = 4.19023e-05, No Iterations 2
ExecutionTime = 7653.89 s  ClockTime = 7671 s
Time = 496
DILUPBiCG:  Solving for Ux, Initial residual = 0.000470975, Final residual = 1.31057e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000368262, Final residual = 9.95087e-06, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 3.66406e-05, Final residual = 1.02858e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.00211582, Final residual = 2.01015e-05, No Iterations 18
time step continuity errors : sum local = 0.00211615, global = 7.15807e-05, cumulative = -0.127154
DILUPBiCG:  Solving for epsilon, Initial residual = 0.0003944, Final residual = 3.98107e-06, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00445943, Final residual = 4.20142e-05, No Iterations 2
ExecutionTime = 7658.79 s  ClockTime = 7676 s
Time = 497
DILUPBiCG:  Solving for Ux, Initial residual = 0.000469239, Final residual = 1.27665e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000365393, Final residual = 1.34082e-05, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 5.0851e-05, Final residual = 1.24694e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.00209146, Final residual = 2.08967e-05, No Iterations 154
time step continuity errors : sum local = 0.00219931, global = -5.47e-05, cumulative = -0.127209
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000394246, Final residual = 3.96901e-06, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00447105, Final residual = 4.21189e-05, No Iterations 2
ExecutionTime = 7668.1 s  ClockTime = 7685 s
Time = 498
DILUPBiCG:  Solving for Ux, Initial residual = 0.000474228, Final residual = 1.27292e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000369804, Final residual = 1.17542e-05, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 7.23045e-05, Final residual = 1.57116e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.0020701, Final residual = 2.01235e-05, No Iterations 63
time step continuity errors : sum local = 0.00211732, global = -0.00012504, cumulative = -0.127334
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000393942, Final residual = 3.95612e-06, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00448192, Final residual = 4.22152e-05, No Iterations 2
ExecutionTime = 7674.4 s  ClockTime = 7691 s
Time = 499
DILUPBiCG:  Solving for Ux, Initial residual = 0.00047692, Final residual = 1.27242e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000371529, Final residual = 1.15432e-05, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 9.53324e-05, Final residual = 1.94679e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.00204754, Final residual = 1.80723e-05, No Iterations 730
time step continuity errors : sum local = 0.00190096, global = -2.64022e-07, cumulative = -0.127334
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000393712, Final residual = 3.94621e-06, No Iterations 2
bounding epsilon, min: -0.314136 max: 372313 average: 10397.8
DILUPBiCG:  Solving for k, Initial residual = 0.00449351, Final residual = 4.23151e-05, No Iterations 2
ExecutionTime = 7701.85 s  ClockTime = 7719 s
Time = 500
DILUPBiCG:  Solving for Ux, Initial residual = 0.000511951, Final residual = 1.3066e-05, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.000407941, Final residual = 1.0782e-05, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 7.41097e-05, Final residual = 1.99966e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 0.00213221, Final residual = 2.02643e-05, No Iterations 16
time step continuity errors : sum local = 0.00213662, global = -1.03452e-05, cumulative = -0.127344
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000394417, Final residual = 3.95603e-06, No Iterations 2
DILUPBiCG:  Solving for k, Initial residual = 0.00450856, Final residual = 4.24534e-05, No Iterations 2
ExecutionTime = 7710.26 s  ClockTime = 7727 s
jonmec is offline   Reply With Quote
Old   June 4, 2011, 10:32
Somedody? Please .... help me =]
Old   July 27, 2011, 10:55
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
hi jon! i'm new to foam myself but i think you could try coping the system file from the tutorials folder to your case folder (~/tutorials/incompressible/simpleFoam/airFoil2D/system
) and run it with these settings. Make sure u got the right patches and boundary conditions
you might wanna try setting some monitor points (can't help you much on this) to make sure your results are converging, check your 'stop" criteria too in controlDic
/calim
calim_cfd is offline   Reply With Quote
Old   July 28, 2011, 06:24
BR
Balakrshnan Ramakrishnan is on a distinguished road
I cannot say from the few lines of your log file, that the solution is not converging..
If you have written out the log file,
you can try using tools like PyFoamPlotWatcher to see how the residuals are.
Balakrshnan Ramakrishnan is offline   Reply With Quote
convergence issues, orifice plate, simplefoam
on fully developed duct flow yfyap Main CFD Forum 6 November 7, 2012 10:59
Fully developed flow ,CEL expression kmgraju CFX 0 August 6, 2010 05:15
Fully developed flow profile icfd Main CFD Forum 3 May 20, 2009 23:21
what is the fully developed fluid flow? charles CFX 7 November 13, 2006 10:48
fully developed duct flow Xing Zhang Main CFD Forum 2 August 2, 2006 20:00
