Parallel run of OpenFOAM in linux and windows side by side |
May 31, 2011, 10:10 |
Mohammad
Rep Power: 16 |
hi all,
I am OpenFOAM user and I will use it for my thesis simulations. but as my university HPC is windows based, I cannot run OpenFOAM in parallel on nodes of HPC. I wanted to know if it is possible to have an OpenFOAM run parallel in linux and windows side by side.(eg. linux as host node and windows as other computing nodes) thank all in advance... |
June 7, 2011, 09:40 |
you should contact Professor Jasak! h.jasak(at)wikki.co.uk or hrvoje.jasak(at)fsb.hr He was involved in a microsoft funded project http://web.student.chalmers.se/group...SlidesOFW5.pdf read beginning Slide 21 =>New Features in Upcoming Release Native Windows Version of OpenFOAM form push Major piece of work, actively supported by Microsoft: HPC platform push (OpenFOAM: Year in Review – p. 21 = Slide 21). But I do not know if you can get it from him? Tell me your experience what Professor Jasak said please others worked in the same direction but without success http://www.scai.fraunhofer.de/openms...ortierung.html (well german use translate service from google) |
June 9, 2011, 16:43 |
Mohammad
Rep Power: 16 |
hi,
thank you elvis for your attention. but it seems my problem is a BIG problem (according to German web page you sent. so I think I'd better to forget about it as I don't have enough time to find a way to have openfoam parallel in lin and win side by side. I posted another post in a thread similar to this but the oppsite! I thought if running FLUENT parallel in windows and linux side by side(win as host and linux as computing nodes) is easy, I can install linux on all computing nodes and use them to run parallel openfoam. this way other students will have no problem running fluent, too. the thread is : http://www.cfd-online.com/Forums/flu...pc-2008-a.html do you have any idea about that? anyway thank you ... |
June 23, 2011, 07:53 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings m2montazari,
I guess I'm a bit late to reply, but I only saw this thread the other day, so I don't know if you've found a solution by now. I would like to add to this thread to tell you that there are a few other possibilities for running OpenFOAM in Windows, which are listed here: Cross Compiling OpenFOAM in Linux For Windows with MinGW - Section "Other Important Links" As the title indicates, these are mostly cross-compiling solutions, namely built in Linux for running in Windows. They are not likely to be faster than a native build such as the one developed by Professor Jasak, but at least a few versions are out there, some open and free (and barely supported) and others with paid support. As for using both Linux and Windows machines, it really depends on the type of work scheme you are looking for:
If it's the second one, you will have to use either MPICH2 or OpenMPI and a crowbar to open Windows HPC's skull. It's just that Windows HPC says on one side that its job scheduler can work with MPICH2 as well, but on the other side they say that you're better off using MS-MPI. But don't take my word for it, ask the support team for your Windows HPC cluster For post-processing, ParaView can work with either one of these setups:
Either way, if you want support for the implementation, you can check with at least one of these products and respective companies:
Bruno
June 23, 2011, 14:57 |
Hi.
at the OpenFOAM Workshop http://www.openfoamworkshop.org/6th_...sak_slides.pdf Hrv Jasak gave an outlook on the windows porting efforts he made => see Slide 4 This time a working demonstration was given. Todo is the HPC capabilities on Windows HPC 2008, but I believe it takes some time before we see it on GIT |
June 24, 2011, 04:26 |
Mohammad
Rep Power: 16 |
thanks a lot for your attention and replies,
to be honest I don't have so much information about computers and related... as I am a mechanical Eng. I mostly work with related softwares. but I know in our university we have about 100 computing nodes(all of the nodes are core2due or corei7) connected to a server system with ethernet cables. nodes OS is win XP x64 and server is win server 2003(not sure 2003 or 2008!).and we have console system which users(like me) open cases and run their cases in parallel mode using those computing nodes. most users use fluent as their CFD software and they dont have any problem with win. but as I and some other students started using openfoam,we have trouble with win. we have a seperated linux console now but I dont know how we can run our cases in that console in parallel mode using computing nodes for proccess. as I mentioned I can change some computing node OS to linux, but other students who wanted to use fluent would have trouble! BTW if it is necessary to install openfoam on all computing node to make them usable to run openfoam on them, it seems the bluecfd product is a good choice. any other helps are so welcomed... and thanks |
linux, openfoam, parallel, windows |
Dual Boot Windows and Linux and Go Open Source | andyj | Main CFD Forum | 2 | October 21, 2010 17:49 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 07:25 |
Cannot run Star-CCM+ parallel in Linux | dburns | Siemens | 9 | April 27, 2010 13:01 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 16:39 |
Parallel in Windows and Linux ? | FRED CHEN | CFX | 2 | June 27, 2005 06:59 |
