May 21, 2011, 10:39 |
Problems With courant number Icofoam
Stephen
Rep Power: 17 |
Hi all
running a simple pipe with 4 outlets. 16mm dia and 800 long ( 3 m/sec volocity ( too fast?? for Icofoam ?) through 2 right angle bends and exercise in learning. Exported as STEP ,set up and meshed in Salome , exported using ideasToFoam so far so good , Calculated the courant Number as per instructions. ( problem 1 when exporting a mesh where is the cell size < I used checkmesh but.... Used Netgen I THINK the cell size is 0.3) I can get it to run but only with the following control dict application icoFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 0.008; deltaT 0.004;//0.005; writeControl timeStep; writeInterval 1; purgeWrite 0; writeFormat ascii; writePrecision 9; writeCompression uncompressed; timeFormat general; timePrecision 9; any other changes or outside of the ratio..0.008 to 0.004 and I get a large courant number and a floating point exception even with a ridiculously small time step and end time What am I doing wrong ? Have I defined the problem correctly do you think? Kind regards Stephen Last edited by basilwatson; May 21, 2011 at 11:19. |
RMS Courant Number vs MAX Courant Number | zoozoozoo | Main CFD Forum | 3 | June 12, 2012 14:44 |
Courant number, patches, etc | oort | OpenFOAM | 1 | July 24, 2009 19:05 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
Cell Courant number | T | FLUENT | 0 | January 18, 2008 04:27 |
COURANT NUMBER | Ferreira | Main CFD Forum | 23 | February 26, 2006 19:10 |
