Running in parallel error
Old   May 7, 2011, 09:44
Default Running in parallel error
Madeleine P. Vincent
Madeleine P. Vincent is on a distinguished road
Hi OpenFoam folks,
I ran the damBreak tutorial successfully on my desktop computer in pseudo-parallel, ie, run it as parallel but on 1 CPU. This created 4 processes that were run simultaneously on 1 CPU.
However, when I tried to run the same problem on our cluster, I got errors. We use the Sun Grid Engine for queuing.
When the run begins, the new time step directories are created in each Processor sub-directory. In addition, I see via "top" that 4 processes are created on the node, but they appear to be executing on a single CPU (their % usage adds up to about 100%).
And then the run fails. I receive the following as an error log from queuing engine:
[[8641,1],0]: A high-performance Open MPI point-to-point messaging module
was unable to find any relevant network interfaces:
Module: OpenFabrics (openib)
Host: node13
Another transport will be used instead, although this may result in
lower performance.
[node13:29545] 3 more processes have sent help message help-mpi-btl-base.txt / btl:no-nics
[node13:29545] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
I am running with the command:
mpirun -np 4 interFoam -parallel
Does anyone have suggestions?
Thanks in advance,
Maddy.
Madeleine P. Vincent is offline   Reply With Quote
parallel error
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 21:23
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 07:12
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
