How to get rid of the defaultFaces, Courant number diverge. |
Guifan Li
Rep Power: 15 ![]() |
Dear all,
I want to simulate an artery with bifurcation. After using Gmsh to generate a mesh file and convert it to openfoam. You can see the screenshot in attachment, there are one "inlet", one "straight_outlet", one "bent_outlet". And there are some defaultFaces at the interaction. When I using icoFoam to run the file, the program will be interupted because courant number become to large. I am just wondering it that because the defaultFaces at interaction block the fluids entering the bifurcation(daughter arteries)? How can I get rid of the defaultFaces, I mean delete them( I can not delete it in gmsh, and delete them in polyMesh/boundary as well)? Here are my p and U file. U dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { artery_wall { type fixedValue; value uniform (0 0 0); } inlet { type fixedValue; value uniform (0 0 -0.11); } straight_outlet { type zeroGradient; } bent_outlet { type zeroGradient; } } p dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { artery_wall { type zeroGradient; } inlet { type zeroGradient; } straight_outlet { type fixedValue; value uniform 0; } bent_outlet { type fixedValue; value uniform 0; } } |
Guifan Li
It may be because of the other problems which I haven't figure out.
Here is my controlDict file application implicitFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 0.1; deltaT 0.001; writeControl timeStep; writeInterval 10; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable yes; libs ("ResistanceBC_relaxed.so"); the length of the artery is around 0.01-0.03 m. regards |
Courant number | fireman | FLUENT | 7 | September 11, 2021 11:33 |
IcoFoam unstability, courant number gets large! | vivien | OpenFOAM | 11 | March 9, 2017 03:45 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
COURANT NUMBER | Ferreira | Main CFD Forum | 23 | February 26, 2006 18:10 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
