evapPhaseChangeFOAM
Like Tree15Likes
Old   September 25, 2017, 13:02
Question
  #101
Elham
Elham is on a distinguished road
Originally Posted by nimasam View Post
Dear Elham
Please re-read my points, you will figure out how it is derived.
equation 18:
lets consider S=-mDot(1/rho1-alpha1(1/rho1-1/rho2)))
then source terms for boiling and condensations would be:
Sb=S*alpha1
Sc=S*(1-alpha1)
Also i mentioned in previous post that:
then right hand side of equation 18 becomes:
so alpha1*div(U) is appearing here
now consider boiling and condensation separately,
for boiling the source term is Sb=S*alpha1
so
for condensation Sb=S*(1.0-alpha1), then:
Sorry but I am still confused.
Base on
ddt(alpha1)+div(U,alpha1)+Sp*alpha1+Su=0
For boiling it should be :
Sp=- div(U) and Su= -S
Elham is offline   Reply With Quote
Old   September 25, 2017, 13:50
Nima Samkhaniani
nimasam is on a distinguished road
i said Sb=S*alpha1, if you consider Su=S, then you missed alpha1 in equation.
about negative signs, it is better to refer the code to see the exact formulation of MULES, i may missed the signs in post
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   September 26, 2017, 11:11
Elham
Dear Nima,
Thanks for all kind answers. I got the idea.You have separated the general source term into two parts; condensation and boiling so that S=Sb+Sc. Then for the boiling phase you just have Sb as source term and for condensation just Sc.
Cheers,
Elham
Old   November 4, 2017, 15:35
Cláudio Corrêa
claudiocor is on a distinguished road
i have developed a solver based on interFOAM, to solve energy equation and besides consider mass transfer between two phases, this solver works correctly for one dimensional case (stephan phase change problem)
but for two case studies, temperature at interface behaves strangely
now any suggestion, cooperation or idea will be helpful
P.S
developed files and case studies are available in attachment
some descriptions can be found here:
http://www.4shared.com/document/-eBG...OF_method.html
Hi nimasam
I'm interested in this problem too. I have trying to solve the problem of water vapor condensation in vertical pipe. My problem is three-dimensional. Could you help me solve this problem? I'm used OpenFoam 4.1
claudiocor is offline   Reply With Quote
Old   November 5, 2017, 07:21
Nima Samkhaniani
Dear Cláudio Corrêaread this post, i upload a solver based on OpenFOAM_2.2.0 which considers both evaporation and condensation and it is suitable for your work
Old   December 6, 2017, 01:42
Default constructor classes
  #106
Elham
Dear Nima,
I am wondering why you defined two different word classes, word& type and word& alpha1Name in phaseChangeHeatFoam?
In constructor of phaseChangeTwoPhaseMixture.C you have:
Foam:haseChangeTwoPhaseMixture:haseChangeTwoPh aseMixture
const word& type,
const volVectorField& U,
const surfaceScalarField& phi,
const word& alpha1Name
I would appreciate if you let me know.
Cheers,
Elham
Old   February 14, 2018, 04:28
Default anonymous term in energy equation
  #107
Elham
Dear Niam,
Regarding to phaseChangeHeatFoam the energy equation (25) in your paper is :
ddT + div (UT) - lapplacian (k/rhoC, T) = -1/rhoC *mdotTriplePrime*Hlg
there is a term in TEqn.H in line 19
- fvm::Sp(fvc::div(phi),T)
which is not corresponding to any term in energy equation.
The whole left side of TEqn is as following:
    fvScalarMatrix TEqn
          fvm::ddt(T)
        + fvm::div(phi, T)
        - Foam::fvm::laplacian( k/rhoC_ , T,"laplacian(alphaEff,T)")
            fvc::div(fvc::absolute(phi, U), p)
          + fvc::ddt(rho, KE) + fvc::div(rhoPhi, KE)
          )/rhoC
Would you please explain a bout it?
Regards,
Elham
Old   February 14, 2018, 06:27
Saicharan
wavefunction is on a distinguished road
Hi Nima Sam.
Could you kindly send me your solver to the email ID saicharanb56@gmail.com ? I would really appreciate it.
I am trying to simulate sessile droplet evaporation and I believe your solver will be ideal for me. I am, however, new to OpenFOAM and do not possess enough skill to code my own solver.
Thanks in advance.
wavefunction is offline   Reply With Quote
Old   February 20, 2018, 02:10
Nima Samkhaniani
Dear Saicharan
please look this post
Old   February 25, 2018, 13:22
Nima Samkhaniani
Originally Posted by Elham View Post
Dear Niam,
    fvScalarMatrix TEqn
          fvm::ddt(T)
        + fvm::div(phi, T)
          )/rhoC
Regards,
Elham
fvc::div(phi)=0, so theoretically it is zero, but numerically it is not, and it help numerical stability
Old   February 25, 2018, 21:32
Elham
Thanks.
Elham
Old   July 20, 2018, 11:12
Przemek
gaza is on a distinguished road
Dear Niam,
    fvScalarMatrix TEqn
          fvm::ddt(T)
        + fvm::div(phi, T)
          )/rhoC
Regards,
Elham
Dear Elham,
It is also written in the documentation
https://openfoam.org/release/2-2-0/n...s-boundedness/
According to this link the same can be achieved with
setting divergence scheme as bounded in fvScheme file, e.g.
 div(phi,T)      bounded Gauss upwind;
Elham likes this.
best regards
pblasiak
gaza is offline   Reply With Quote
Old   May 18, 2022, 09:14
hari charan
saicharan662000@gmail.com is on a distinguished road
Hi nimasam,
Could you tell me how you solved your problem if not possible to send .If you can send you can mail me to this mail : saicharan662000@gmail.com
Thanks and regards
saicharan662000@gmail.com is offline   Reply With Quote
Old   February 24, 2023, 16:17
Default Ancient code
  #114
Michael Jensen
mikethe1wheelnut is on a distinguished road
Dear foamer
The latest version of my solver (phaseChangeHeatFoam), several test cases and published papers are available in github.
https://github.com/NimaSam/phaseChangeHeatFoam/
please inform me about possible bugs.
Best Regards
To anybody like me finding this post all these years later, it uses openfoam 2.2.0, for which installation instructions exist only to up only to ubuntu 13.10, which is, in this case, unsupported and obsolete. If you follow those instructions, they will not succeed. Because the files they depend on won't be there. I have contacted the author about this and been directed to.. I can't recall where, (..I could track it down..) but it was one of the documentation pages you'll find if you search for evaporation/concensation/openfoam. So this is merely a confirmation of what you surely already expect. I can vouch that the author is very friendly if you are reasonable with whatever request you might make :-)
Best regards, Mike :-)
mikethe1wheelnut is offline   Reply With Quote
Old   October 13, 2024, 23:25
shamiaoluo
BUAA LSM is on a distinguished road
Please clicHello, Nima Sam.
Would you be so kind to send your code to zy2104210@buaa.edu.cn?
Thanks in advance!k one of the Quick Reply icons in the posts above to activate Quick Reply.
BUAA LSM is offline   Reply With Quote
Old   October 14, 2024, 04:06
Default boiling solvers
  #116
Nima Samkhaniani
Hi dear foamer
it is interesting that after 6-7 years still i can see some people interested in phaseChangeHeatFoam. The solver is validating for film boiling alot with different authors. However, It was written for OpenFOAM-2.3 and I never tried to upgrade it higher version of OpenFOAM.
but you can find lots of attempt in literature for developing phase change solver in OpenFOAM. e.g:
1- OpenFOAM standard solver (interCondensatingEvaporatingFoam from esi version)
2- boilingFoam (https://github.com/fmuni/boilingFoam-PUBLIC)
zrxdaly likes this.
boiling, evaporation, interfoam, phase change
