evapPhaseChangeFOAM
Like Tree15Likes
Old   March 31, 2016, 10:07
Default boiling in openFOAM with evapPhaseChangeFOAM
  #81
Shyam Sunder
ssyadav is on a distinguished road
Hello Nimasam
Kindly send me the OpenFoam based code to simulate boiling with OpenFoam. My email id. is ssyadav25@gmail.com
Thanks in advance.
Shyam Sunder
ssyadav is offline   Reply With Quote
Old   May 15, 2016, 06:44
Default VOF solver for condensation
  #82
Elisabet Mas de les Valls
elisabet is on a distinguished road
Nima and Alexander,
I'm a little bit confused about the state of the art of your solvers. I'ld really appreciate you could send me your codes and, if possible, comments. I'll try to understand the differences and limitations.
I'm currently interested in steam condensation, so any suggestion is welcome!
Thank you in advance,
Elisabet (elisabet.masdelesvalls@gits.ws)
elisabet is offline   Reply With Quote
Old   May 16, 2016, 16:29
Alexander
sahas is on a distinguished road
Hello, Elisabet!
Currently I have no deal with simulation of evaporation/condensation using VOF method. Some information about evaporation model implementation can be found in this thread. Still remaining problem is taking correctly into account the latent heat. As mentioned in the literature, the possible solution is to introduce weight function in such a way that the integral from the volume latent heat source multiplied by this weight function gives the value of correct latent heat power. Unfortunately, I do not have much information about this.
sahas is offline   Reply With Quote
Old   May 30, 2016, 22:51
LONG JIAO
serena_bears is on a distinguished road
Hi Nimasan,
could you please send me your final code? Now I'm working on droplet condensation problem. Thank you very much.
My email is LONG0032@e.ntu.edu.sg
serena_bears is offline   Reply With Quote
Old   July 15, 2016, 10:21
Shen shiquan
Location: The State Key Laboratory of Engines (Tianjin University)
tju_shq is on a distinguished road
Hi Nimasan,
My email is shiquan@tju.edu.cn
tju_shq is offline   Reply With Quote
Old   September 9, 2016, 16:48
Exclamation Link to solver files not working
  #86
Aslamah Rahman
asla9796 is on a distinguished road
Hello, I am new to CFD and is trying to simulate the same problem of droplet evaporation. This link posted in the thread which contains the files for solver appears to be empty now. Please do look into this and do share the code again if possible.
My mail ID is mm14b007@smail.iitm.ac.in
Thank you for your time
asla9796 is offline   Reply With Quote
Old   September 11, 2016, 11:50
Przemek
gaza is on a distinguished road
Hi
for now my code does work
I will share my code when it will work
see to OpenFOAM 1606 there is interEvaporatingCondensingFoam
best regards
pblasiak
gaza is offline   Reply With Quote
Old   September 20, 2016, 12:20
AndyKing
Ank09 is on a distinguished road
Hi Nimasam!
I'm working on the droplet evaporation topic and I'm very interested in your code. Could you please send me a copy of your final code?
Thanks a lot! My best wishes!
My email: andyking0928@foxmail.com
Ank09 is offline   Reply With Quote
Old   April 1, 2017, 13:16
Gautham Krishnan
GauthamKrishnan is on a distinguished road
Hi Nimasam!
I'm working on the droplet evaporation and I'm very interested in your code. Could you please send me a copy of your final code+ case file
My email: [email]gkriz66@gmail.com
GauthamKrishnan is offline   Reply With Quote
Old   June 7, 2017, 05:41
Default phaseChangeHeatFoam
  #90
Nima Samkhaniani
nimasam is on a distinguished road
Dear foamer
The latest version of my solver (phaseChangeHeatFoam), several test cases and published papers are available in github.
https://github.com/NimaSam/phaseChangeHeatFoam/
please inform me about possible bugs.
Best Regards
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 7, 2017, 13:41
Default phaseChangeHeatFoam compilation error
  #91
Shyam Sunder
Dear Nima
Thank you very much for posting your solver. I tried compiling it in OpenFOAM 2.2.2, I am getting some errors which are as follows:
1) smoothInterfaceProperties.C:27:49: fatal error: alphaContactAngleFvPatchScalarField.H: No such file or directory
#include "alphaContactAngleFvPatchScalarField.H"
I could resolve this error by changing the path in the "smoothInterfaceProperties/Make/options" file
2) /usr/bin/ld: cannot find -ltwoPhaseInterfaceProperties
This library is included in "phaseChangeHeatFoam/Make/options" but I could not locate it my OpenFOAM installation.
Please help.
Also how I can extend your solver to include Conjugate heat transfer in a solid, particularly the boundary condition at the solid-fluid interface, i.e. the incompressible version of "compressible::turbulentTemperatureCoupledBaffleMi xed"
Thanks.
Shyam
Old   June 8, 2017, 02:46
Nima Samkhaniani
Dear Shyam
1- for your second question, i guess the name of library has been changed in newer version of OpenFOAM, i dont have OpenFOAM-2.2.0 to check it my self. but i guess it became libtwoPhaseProperties or libinterfaceProperties
2- you can see this paper
Old   August 31, 2017, 13:13
Elham
Elham is on a distinguished road
Originally Posted by nimasam View Post
Dear Shyam
Dear Nima,
I cannot compile your code due to the following error:
In file included from phaseChangeHeatFoam.C:57:0:
createFields.H: In function ‘int main(int, char**)’:
createFields.H:106:72: error: no matching function for call to ‘Foam::smoothInterfaceProperties::smoothInterfaceProperties(Foam::volScalarField&, Foam::volVectorField&, Foam::phaseChangeTwoPhaseMixture&)’
Do you have any idea to fix it?
Cheers,
Elham
Elham is offline   Reply With Quote
Old   August 31, 2017, 14:44
Nima Samkhaniani
1-which version of openfoam, do u use?
2-you should first compile smoothInterfaceProperties using following command:
wmake libso
then you can compile the solver
Old   September 1, 2017, 09:53
Elham
The library is compiled but still have the error. I use OpenFOAM 2.3.0.
Old   September 2, 2017, 02:19
Nima Samkhaniani
Dear Elham it's been written for OpenFOAM_220, for upper versions of openfoam, you may need to change some of libraries name, because the basic solver which is interfoam is changed a lot through openfoam 2.2 to openfoam 3.0
Old   September 22, 2017, 13:06
Elham
Dear Nima,
I have read your paper "The evaluation of the diffuse interface method for phase change simulations using OpenFOAM" and the phaseChangeHeatFoam code. To derive Sp you have used the right hand side of equation 18 but I am still wondering how you have derived su , as part of source term?
I would appreciate if you give me some clues.
Cheers,
Elham
Old   September 23, 2017, 05:01
Nima Samkhaniani
Several points to clarify coding:
1)as i remember the formulation of MULES is like that:
ddt(alpha1)+div(U,alpha1)+Sp*alpha1+Su=0
2- convection term in equation 18, then:
U & grad(alpha1)=div(U,alpha1)-alpha.div(U)
3-the mass transfer source term is multiplying with void fraction, means:
mDotBoiling=mdot*alpha1;
mDotCondensation=mdot*(1-alpha1);
Old   September 25, 2017, 02:10
Elham
Dear Nima,
I am confused about deriving the source terms. Equation 18 is as following:
ddt(alpha1)+U& grad(alpha1) +grad(alpha1(1-alpha1)Uc) = -mDot(1/rho1-alpha1(1/rho1-1/rho2)))
and in eq 16:
div (U) = mDot(1/rho2-1/rho1)
substituting eq 16 into eq 18 and rearranging:
ddt(alpha1) + grad(U,alpha1) + grad (alpha1(1-alpha1)Uc) = -mDot/rho1
So we should have:
sp = 0 and su = mDot/rho1
But in alphaEqn.C:
sp=mDot(1/rho1-alpha1(1/rho-1/rho2))
su=divU*alpha1 + mDot(1/rho1-alpha1(1/rho-1/rho2))
Thnaks for any help.
Elham
Old   September 25, 2017, 12:21
Nima Samkhaniani
Dear Elham
Please re-read my points, you will figure out how it is derived.
equation 18:
lets consider S=-mDot(1/rho1-alpha1(1/rho1-1/rho2)))
then source terms for boiling and condensations would be:
Sb=S*alpha1
Sc=S*(1-alpha1)
Also i mentioned in previous post that:
U & grad(alpha1)=div(U,alpha1)-alpha1*div(U)
then right hand side of equation 18 becomes:
dt(alpha1)+div(U,alpha1)-alpha.div(U) +grad(alpha1(1-alpha1)Uc)
so alpha1*div(U) is appearing here
now consider boiling and condensation separately,
for boiling the source term is Sb=S*alpha1
so
su=alpha1*div(U)
sp=S
for condensation Sb=S*(1.0-alpha1), then:
su=alpha1*div(U)+S
sp=-S
boiling, evaporation, interfoam, phase change
