evapPhaseChangeFOAM
Like Tree15Likes
Old   March 26, 2015, 17:51
Mostafa Mobli
moblimostafa is on a distinguished road
Dear Nima
Could you send me your your code?
mostafamobli@gmail.com
moblimostafa is offline   Reply With Quote
Old   April 23, 2015, 14:22
Yaoyina
yaoyina is on a distinguished road
Hello, Nima Sam.
Would you be so kind to send your code to yao-yn14@mails.tsinghua.edu.cn?
Thanks in advance!
yaoyina is offline   Reply With Quote
Old   May 26, 2015, 16:09
Chad
chaolian is on a distinguished road
Hi, Nima
Thanks for your contribution. I am interested in your solver.
Could you please send your solver to me: chaolian@mtu.edu
Thanks in advance.
chaolian is offline   Reply With Quote
Old   May 27, 2015, 17:11
Kanarya is on a distinguished road
Hi Nima,
I am also interested in your code
kah.recep@gmail.com
thanks in advance!!
Kanarya is offline   Reply With Quote
Old   July 9, 2015, 00:50
smraniaki is on a distinguished road
Hello Nimasam
Thank you very much for your contribution to the world of OpenFoam. I am also interested to see your code. Would you please email it to rifel2002@yahoo.com
Smran
smraniaki is offline   Reply With Quote
Old   August 7, 2015, 10:36
Przemek
gaza is on a distinguished road
Hi Nima Sam,
I compiled your solver but the results are wrong.
I used the fluids properties the same as Bitan Shu. You can see here
http://www.cfd-online.com/Forums/ope...pvofhardt.html
I am also trying to do solver for evaporation/condensation but my results are also wrong.
Can anybody upload correct solver for evaporation/condensation purposes?
best regards
pblasiak
gaza is offline   Reply With Quote
Old   August 7, 2015, 10:46
I do not think, there is correct one!
what is wrong with your results?
Originally Posted by gaza View Post
Hi Nima Sam,
gaza likes this.
Old   August 11, 2015, 04:43
Przemek
Hi Kanarya,
In attachement
http://fluid.itcmp.pwr.wroc.pl/~pblasiak/download.html
there is stefan problem case with settings as in Bitan Shu conference paper:
http://pl.scribd.com/doc/28869783/Pa...0080214#scribd
Additionally there is file interfacePosStefProbl_analSol.dat where are analitycal results for this case for time 0-25 s. For 25 s interface position should be 3.8 mm but numerical value is much smaller (see figure in the attachement).
I created my own solver. Results are close to analytical but still incorrect.
I uploaded this with damBreak case here
http://www.cfd-online.com/Forums/ope...-modeling.html
In Nima Sam I also added additional term as in my solver in TEqn.H to avoid unboundedness in temperature field.
What do you think about Nima Sam solver and my?
Do you know what is wrong?
Did you validate Nima Sam solver on damBreak case?
best regards
pblasiak
Old   August 11, 2015, 05:50
Hi Gaza,
Which solver is yours?
Do you consider that your water or vapour is reached in saturation ?
If not, you need source and sink term for both phases...
For instance, if water is cool enough, it needs to gain energy in order to evaporate for this reason you need source term...
Best regards,
Old   August 11, 2015, 07:54
Przemek
Hi Kanarya,
My solver is interEvapCondPhaseChangeFoam (first link). The second link is a test case for solver
evaPhaseChangeFoamU (solver created by Nima Sam). As you can see in the figure in attachement
numeirical results is not equal analytical, which should be 3.8mm for 25 s for fluid properties used (see Bitan Shu paper). Why do you think that Nima Sam solver works well?
I did not consider that water is in saturation condition because I do not know how to provide this or
temperature at interface equal to saturation temperature. I only used initial conditions for water close to saturation temperature.
Here you can see how to compile my solver
If you run stefan problem with my solver you can see that results are close to analytical but still not well. It is clear in damBreak case where you can see the difference in comparison to interFoam.
Do you know how can I improve my solver?
best regards
pblasiak
Old   August 11, 2015, 08:04
Przemek
Originally Posted by Kanarya View Post
Hi Gaza,
Best regards,
And one more question: what do you mean "you need source and sink term for both phases"?
My TEqn looks like
fvScalarMatrix TEqn
fvm::ddt(rhoCp, T)
+ fvm::div(rhoPhiCpf, T)
- fvm::Sp(fvc::ddt(rhoCp) + fvc::div(rhoPhiCpf), T) // additional term to avoid uboundedness ot T
- fvm::laplacian(kappaf, T)
fvm::Sp(hEvap*(mCond + mVap)/T, T)
hEvap - enthalpy of vaporisation
mCond - mass due to condensation
mVap - mass due to evaporation
mCond and mVap are calculated using phase change model. In this case Ganapathy.
best regards
pblasiak
Old   August 11, 2015, 08:07
As I can see here you did not specified for which phase you are solving T equation right?so there is not volume fraction of alpha or sth?or I am wrong?
My TEqn looks like
fvScalarMatrix TEqn
fvm::ddt(rhoCp, T)
Old   August 11, 2015, 08:12
Przemek
I created my solver based on interPhaseChangeFoam. In VOF energy equation is solved for both phases.
best regards
pblasiak
Old   August 11, 2015, 08:18
yes but if you look to the solver alpha.H it is only solving for one phase not like two fluid model, if you check the twoPhaseEulerFoam you will see...
what is you final gaol...what do you want to simulate with this solver ...probably two fluid model suits you better...
Old   August 11, 2015, 08:30
Przemek
yes but I want to use one fluid approach because it is less computationally expensive.
I think that alpha equation in my solver is solved in wrong way but I do not know how to fix it.
Are you using Nima Sam solver? What do you think about results of it?
best regards
pblasiak
Old   August 11, 2015, 08:31
no I am not...I do not have it..could you please send it to me ?
Old   August 11, 2015, 08:44
Przemek
yes of course, here it is (third link):
it is for OF1.6.x
best regards
pblasiak
Old   September 21, 2015, 02:24
Default Hi Nimasam
  #78
Akr
NightWing is on a distinguished road
Can i get the final code???
email: arunkraj03@gmail.com
NightWing is offline   Reply With Quote
Old   December 23, 2015, 07:54
thomas
thomas. is on a distinguished road
Hi Nimasan,
could you please send me your code?
My email is thomas.schaub.h@gmail.com
Thank you very much in advance!
thomas. is offline   Reply With Quote
Old   December 29, 2015, 05:14
Smile
  #80
LCC
Li Cong
LCC is on a distinguished road
Hello, nimasam. I have some problems about two phase change progress. Can you send me your final code? My email is 18600156862@163.com. Thank you very much!
LCC is offline   Reply With Quote
boiling, evaporation, interfoam, phase change
