Linear Elasticity
Old   April 19, 2011, 11:00
Default Linear Elasticity
Chris
topopt is on a distinguished road
i dont know where exactly i should put this thread, so i have started it here.
I want to solve a linear elasticity problem in 2D and 3D using openFOAM. The structure is given by a levelset function, i.e. negative sign means material, positiv sign means no material, and zero value on the boundary.
the levelset function is defined on a rectangular box.
I am new to openFOAM, so these are my questions:
how can i create a (structured) mesh for the structure, given the level set function on a rectangular grid?
can i use the ersatz material approach, i.e. material with less density ( ~factor 10e-03) is filled in the gaps?
greetings, and thanks
topopt is offline   Reply With Quote
please help me which solver is better for my application Ger_US OpenFOAM 8 January 8, 2013 13:29
turbDyMFoam settings MichiB OpenFOAM Running, Solving & CFD 2 August 4, 2010 09:14
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 02:23
IdeasUnvToFoam Bug amp Fix benru OpenFOAM Bugs 42 November 13, 2009 08:59
Water pump OpenFOAM 15 ANSYS CFX 110 comparation waynezw0618 OpenFOAM Running, Solving & CFD 39 March 5, 2009 13:57
