April 21, 2011, 05:22 |
#21 |
Antonio Liggieri
Rep Power: 15 |
@santiagomarquezd - yea sure, of course I do attatch an "outlet box", in order to get a physically realisic profile instead of an artificial one caused by my bc.
@alberto - so as I understand you; the p_rgh is always uniform, but the value must not be 0. It's only 0 if the "sea level" outside my domain is at z=0, because the codes refenence is at z=0. In case "sea level" should NOT be at z=0, p_rgh varies. Is the sea level at z > 0, p_rgh is > 0 as well, is the sea level at z < 0, p_rgh is < 0. Is this the way how hydrostatic pressure is taken into account? |
April 21, 2011, 06:01 |
#22 |
Alberto Passalacqua
Rep Power: 36 |
Take a look at how rho*g*h is defined in the code (createFields.H, line 109).
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
September 14, 2011, 08:30 |
#23 | |
Jindo
Rep Power: 15 |
I have a question. Domain (mesh) which you are using is new in this solver or repaired of old domain. You can tell me how to creat new application (mesh) , it must to match with attributed in 0 directory.....? and did you choose a mesh of solver ?? I repaired the file blockMeshDict of backward facing (scalarTransportFoam) to have the new mesh. however, it rdidn't run similarly with solution your. they attached the following image in the link: http://www.cfd-online.com/Forums/ope...tml#post323465 thanks ! cheers Phuc |
interFoam (OF 1.7.1) in parallel ..need help | farhagim | OpenFOAM | 4 | July 26, 2012 17:42 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 05:43 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 06:29 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
