Convergence/flow development airfoil
Like Tree4Likes
Old   April 11, 2011, 03:46
MadsR's Avatar
Mads Reck
MadsR is on a distinguished road
Hi Felix,
sorry for the late reply and thanks a bunch for your kind and fast help. I know that José is working on it, using your suggestions, and we will report back with the outcome.
Thanks again,
Mads
Online free airfoil-mesher for OpenFOAM here
MadsR is offline   Reply With Quote
Old   April 14, 2011, 04:43
jms
José
jms is on a distinguished road
Hi Felix,
As Mads just said sorry for being so late to give you an answer.
What I had wrong was the fvSolution file. Some of the tolerances were quite high that OF could not solve the equations correct and this is why it was taking so long time.
Furthermore, since the equations are solved better I don´t have this strange behavior on the drag curve for the NACA0012 I sent to you some time ago.
Thank you very much for all your help. It has really helped for the work I am doing in the thesis.
Best regards,
José
jms is offline   Reply With Quote
Old   April 14, 2011, 05:22
Felix L.
FelixL is on a distinguished road
Hello, José,
I'm glad to hear that your problem is solved and I could be of help. Feel free to ask anytime when there are new problems showing up (but which I really hope they don't).
Good luck with your thesis!
Greetings,
Felix.
FelixL is offline   Reply With Quote
Old   May 17, 2011, 04:44
Jordi Muela
jordi.muela is on a distinguished road
Hi everyone,
I'm validating a model to use it for find the Cd values of different geometries at different Re. Now I'm using a sphere due that is a geometry with a lot of experimental data.
I'm having similar problems to those mentioned in this thread, so please, can someone post the files fvSolution and fvSchemes which works fine?
I already tested all the suggestions explained in this thread but i couldn't obtain a good solution yet, my p residual it's still to high (and velocity residuals too...)
Thanks a lot,
Jordi.
jordi.muela is offline   Reply With Quote
Old   May 17, 2011, 04:54
jms
José
Hi Jordi,
I post the fvSolution and fvSchemes files which work fine for what I am doing (flow around an airfoil). What it really helped to me when I had convergence issues is to decrease the tolerance of all the residuals to a very low value (i.e. one value that none of them is getting -->1e-16).
But, what do you consider high for the residuals? I am getting residuals for the pressure equation around 1e-4. And the time of the computations when the airfoil is in the stall region is still high.
If you get any new things regarding this thread, plesease, keep me/us posted.
Greetings,
José
Old   May 17, 2011, 06:21
Jordi Muela
Hi Jose,
first of all thanks for your fast reply! Just now i'm running a case with komegaSST model and for the moment, the behaviour seem 'better' than my previous cases, where i used the realizableKE model (Take a look to this report: http://citeseerx.ist.psu.edu/viewdoc...=rep1&type=pdf).
Well, when my current simulation finish, then I test the 'fvSchemes' and 'fvSolution' that you attached and report here how it gone! (Now i'm using the 'fvSchemes' and 'fvSolution' files of the motorBike test case).
With realizableKE I obtained residuals for p arround 1e-2~1e-3 (very high values...) but my tolerance and relTol values were highs too (arround 1e-5~1e-6 for tolerance...), but if I switch this values for others lower then i have divergence problems...
Well, I'll keep you updated about my progress!
Jordi.
Old   May 19, 2011, 07:23
Jordi Muela
Hi José,
after few simulations changing some parameters, turbulent model and mesh, I've arrived at the conclusion that my principal problem is the mesh.
Now i'm getting reasonable results with a mesh where I refined the wake zone. I'm getting this results with the realizableKE model, the kOmegaSST model isn't working much well for me... Although i'm still having residuls for p around 1e-2 ~ 1e-3 (and I'm worried about that, but the results seems to match reasonably with the experimental..)
Thanks a lot for your help!
Jordi.
Old   June 7, 2011, 06:47
jms
José
Dear all,
I have tried to improve the speed of the computations done. I am doing simulations around a 2D airfoil (NACA0012) at Re=3.000.000 using the turbulence model k-w SST and a mesh of 123.000 cells. I have tested how the convergence speed is modified by changing relTol (from fvSolution).
I have used relaxation factor for the pressure equation=0.2 and relaxation factor for the velocity equation=0.8 since I tested once for another airfoil and this is the best I got. You can see the fvSolution file used
I have tested it for relTol=0.001, relTol=0.01 and relTol=0.1, the cases converge in 5, 4 and 6 hours respectively. A case with the same mesh run with ANSYS CFX (using the double precission solver!) takes about 1 hour to converge.
I still have to try it using GAMG solver for the pressure equation and see if I can improve it more...
Doe anybody can give me any comment about this? Any improvement to this is very welcome!
Thanks.
Regards,
José
Old   July 15, 2011, 11:40
aerothermal's Avatar
Guilherme da Silva
aerothermal is on a distinguished road
Send a message via Skype™ to aerothermal
Hello All,
Have you (Mads, José, Felix and Jordi) solved the issue? Do you all have an update?
I am very interested to have the system files and/or the mesh itself.
Just for your information, I saw a huge difference in convergence between OF1.7.1 and OF1.6-ext. The latter had a much better convergence history/duration and result. It may be related to some differences in linear solvers implemented by Jasak and others from extended project.
See some preview of the results at the thread below:
http://www.cfd-online.com/Forums/ope...tml#post307393
Regards,
Guilherme da Silva - ATS4i
aerothermal is offline   Reply With Quote
Old   July 18, 2011, 03:57
MadsR's Avatar
Mads Reck
Hi Guilherme da Silva,
we don't have any significant to add to the above, still OF is much slower (wall clock) than CFX 13 (and other codes I have tested) in terms of getting a final converged solution. Apart from that I am very happy with OpenFOAM 1.7.1 results on 2D airfoils (both normal thin ones and more exotic ones) with and without laminar-turbulent transition modelling (with, thanks to Felix).
Interesting information you have about the 1.7.1 and the 1.6-ext convergence difference, I wonder if 2.0 is better than 1.7.1, we haven't tested that yet, but maybe someone else did? There must be a lot of revisions since they went past 1.8 and 1.9 :-P
Please update us if you find more on this issue
BR
Mads
Old   July 19, 2011, 12:32
Felix L.
Hello, All,
I too don't have anything new to add to the above. Unfortunately I didn't have had much time lately to work with OpenFOAM, but at least I managed to upgrade to 2.0 and test a few things.
I tried to reproduce the NASA NACA0012 validation test cases ( http://turbmodels.larc.nasa.gov/naca0012_val.html ) using the grids they provided. The cases ran well, but I'm unhappy with the results, because I'm not able to get into the asymptotic range with the force coefficients at alpha=0°. That kind of bothers me and I need to look deeper into it at some time, but for now you can have my systems directory - I don't think you'll find anything new there, though.
I didn't notice any improvement performancewise. The new residual control, though, comes in very, very handy!
Greetings,
Felix
Old   July 19, 2011, 12:33
Felix L.
Oh by the way, here's the system-Directory!
Old   October 29, 2015, 12:27
KateEisenhower is on a distinguished road
Hello all, and thank you for this very interesting dicussion.
Felix, what made you choose the SpalartAllmaras model? I thought I read somewhere it is better to choose the kOmegaSST model for high AoAs. Has someone compared these two?
Best regards,
Kate
Originally Posted by FelixL View Post
Hello, Mads,
your OpenFOAM settings don't seem to be optimal to me. I've run airfoil configurations with slightly more complex configurations and grids and I didn't have such extreme convergence times. I used SpalartAllmaras most of the time though, but I don't think the choice of turbulence model would make such a huge difference in terms of convergence rate.
In my opinion, simple airfoil configurations (low AoA, incompressible, 100k-400k cells) should be reasonably converged within a few thousand iterations. But this of course depends upon a lot of things.
What do you use as a starting field? Running potentialFoam first usually accelerates convergence a lot. PCG for solving the pressure equation usually helped a lot for me too (instead of GAMG).
A look at your numerical setup in OpenFOAM would be great.
Greetings,
Felix.
KateEisenhower is offline   Reply With Quote
2-d, airfoil, cfx, convergence, openfoam
Low Speed Airfoil Mancusi FLUENT 7 April 3, 2014 07:11
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
[GAMBIT] Meshing airfoil using .dat file problem creggie ANSYS Meshing & Geometry 10 June 27, 2010 20:24
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) Josh CFX 9 August 18, 2009 12:31
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 19:36
